As I said my reason for the homemade connectors was not cost of the parts or shipping. That was just a side benefit. Not very important to me.
There were four primary reasons:
1. I could work continuously without stopping to wait for parts.
2. I did not have to take the time to order parts.
3. Some of the standard parts do not have the holes in the correct location to use carriage bolts which I considered important.
4. Some of my connectors are custom and not available from any source.
I suspect there might be an easy way to add panels to 10 series. Have not tried to do that. Obviously you could bolt them to the face but I would not like all the visible fasteners or panel edges. Insetting the panels 1/8" so the panel edge does not leave a gap due to the 1/8" corner radius of the series 15 provides a clean appearance.
It was interesting to me that when I first saw a conversion that used the 10 series my reaction was not positive. One look and I decided that I had made the right choice using the 15 series. That was my eyes so others could react differently.
Hope your conversion works out well no matter what series you use. It is a fun process and suspect you will learn some new skills as I did.
Thanks for the clarification. We each have our priorities... and you have the experience gained by building two vans, I'm just starting. But on your four reasons, here's how I see it:
1. I'm more interested in least total effort than in continuous progress. I'm juggling a few other things and I'm fine with doing work in stages.
2. I'm not too concerned about this. Ordering my utility cabinet parts took maybe 10 minutes including specifying machining.
3. I believe this is for your corner brackets? I'm still learning but after more comments here I'm thinking to use mainly end connectors--strong and out of sight, and the required machining operations are simple and non-precision.
4. Good point, and I do expect to fabricate some custom things--looking first through your excellent documentation on parts you've created. But the bulk of my connectors will be standard off-the-shelf with standard machining services.
As to 10 series not looking right to your eye... I'm most interested in maximum function in a small space. With 10 series, I gain a full 2" in opening width across my back gear garage which has 3 bays. This is huge when I'm trying to fit 24" wide sailboards in the righthand bay, 2 bikes in the middle, and the utility cabinet on the left.
Also for drawers in my galley--an extra 1.5" in width is available for same outer galley dimension and sink bay dimension. Vertically, an extra 2.5" in total for drawer heights in a 4 drawer bay.
As for aesthetics, some people like Craftsman style with wide trim and others like European frameless cabinets. I happen to like both, just depends on the house they're in. For my van, I'll have a utilitarian function-driven design. For my taste, I'm not seeing any reason to use double the amount of aluminum at double the weight and cost, while sacrificing precious space, just to have 1.5" extrusions. But that's the beauty of a DIY conversion, to each their own!
