Baja is wonderful this time of year!I’ll get another build going after I return from El Sargento, Baja in about 6 weeks.
Sign me up for one too, please. Have followed this project for ages and have always wanted one of these bad boys!I’ll get another build going after I return from El Sargento, Baja in about 6 weeks.
Baja is as peaceful as ever; at least where I go. I don't drive through Tijuana, but go through Mexicali and take the MEX 5 to Gonzaga Bay. That stretch is a pleasure to drive. Unfortunately due to a sickness in the family I had to cut my stay 2 weeks short. Just got home. The drive back was a bit interesting as I lost functionality of the rear sway bar. Don't know when the "retainer" got lost. The retainer connects the sway bar to the rear axle with 2 bolts. One of the bolts sheared off at the nut that's connected to the axle mount, the other bolt along with the retainer is gone. The suspension/sway actually wasn't that bad, considering I have a top heavy motor home. The Fox shocks help a lot keeping sway under control.Not sure if any of the madness happening on the mainland has made it to Baja. Hope calbiker is ok…
Is that the original sway bar bracket? There have been reports of substandard aftermarket onesBaja is as peaceful as ever; at least where I go. I don't drive through Tijuana, but go through Mexicali and take the MEX 5 to Gonzaga Bay. That stretch is a pleasure to drive. Unfortunately due to a sickness in the family I had to cut my stay 2 weeks short. Just got home. The drive back was a bit interesting as I lost functionality of the rear sway bar. Don't know when the "retainer" got lost. The retainer connects the sway bar to the rear axle with 2 bolts. One of the bolts sheared off at the nut that's connected to the axle mount, the other bolt along with the retainer is gone. The suspension/sway actually wasn't that bad, considering I have a top heavy motor home. The Fox shocks help a lot keeping sway under control.
C-Dash of course works terrific. It gives me a sense of security that the drivetrain is working well. That's especially important when driving in Mexico.
Got to agree, it is a beauty!What is the current price on this beauty?
I have 4 vans i may want to equip with it.
That is the original retainer bracket. Some 15 years ago I switched to a larger sway bar. After doing accelerometer suspension testing I determined the larger SB enhanced slow speed rocking. About 5 years ago I reinstalled the stock SB. I drove about 1000 miles in Baja without a SB.Is that the original sway bar bracket? There have been reports of substandard aftermarket ones
Regards,
Mark
Sounds fair, a little above my pay grade to equip all my vans, but i want two for my primaries.Got to agree, it is a beauty!
So far I haven't changed the price since start; with fan tach, ram ball mount, USB connector: $280 + $15 shipping. Since then, my part costs have increased significantly. I'm just starting to reorder parts for the final 10 units (6 or 7 units may already be spoken for). There could be a $10 or $20 increase. Still the best deal on the planet. No where else can you get this type of data streaming for a OM647 T1N.
Main screen:
speed, rpm, fan rpm, gear, load, boost pressure, torque, odometer, fuel level, fuel consumed, instantaneous mpg, mpg
Temperature: H2O, atf, fan air, ambient, cabin, vent
Eng screen:
speed, rpm fan rpm, egr, load, turbo %, fuel pressure, aux fan status (on/off), boost pressure, oil quality, oil level, battery voltage
Temperature: H2O, atf, oil, fan air
Big screen (easier to read):
speed, rpm, load, boost pressure, torque, mpg, fuel level, oil level
Temperature: H2O, atf, oil, ambient, cabin, vent
Max screen (maximum recorded values):
speed, boost, fam rpm, odometer, A/C pressure (real time data)
Temperature: H2O, atf, oil, fan air, ambient, cabin, C-Dash internal
Cal screen (calibrate):
Date, speed, fuel consumed, fuel reset, file storage (on/off), Tach operation (on/off), display intensity, units (us/metric)
Data logging (6 second interval):
Ambient temp, atf temp, H2O temp, oil temp, fan temp, intake temp, fuel temp, cabin temp, vent temp, boost psi, fuel valve, fuel pressure, speed, load, torque, turbo %, rpm, fan rpm, torque converter slip rpm, throttle position, maf, O2 voltage, lambda, instantaneous mpg, mpg, fuel tank level, fuel consumed, egr, oil level, battery voltage, selected gear, actual gear, Aux fan status, wheel speed sensor (all 4 wheels), trip odometer, internal C-Dash temperature
A buzzer will alarm and data will be highlighted if certain readings are beyond a specified limit.
BTW, it took a couple of years to reverse engineer these proprietary OBD PIDs.
Good suggestion. I have a Aoyue 852A++ Pro that I use to remove parts. Will see how it works installing them. Solder paste is new to me. I've kept some solder paste in the freezer for 3 years. Time to try it out!Do you have an air solderer?
They arent too expensive, and i found it makes surface mount work a breeze...
Pun intended.
If the solder paste has expired (it may separate), I've had good luck with the no refrigeration solder paste. Here's one that's pretty cheap.Good suggestion. I have a Aoyue 852A++ Pro that I use to remove parts. Will see how it works installing them. Solder paste is new to me. I've kept some solder paste in the freezer for 3 years. Time to try it out!
I don't believe my sn42bi58 solder paste has an expiration date. Label says to freeze it. I'm excited to try it out. Besides the new surface mount multiplexer, there's also some surface mount ceramic caps and a linear regulator. I'll get a handle on the easy-to-solder components first.If the solder paste has expired (it may separate), I've had good luck with the no refrigeration solder paste. Here's one that's pretty cheap.
My website in my signature has a link to my TCXO board with info on how it was fabbed. Although I used a reflow oven, it still may be some help.
Regards,
Mark
That's got to be low temperature paste? I have used lead free SAC305, much higher temperature, not easy. I'm a glutten for punishment.I don't believe my sn42bi58 solder paste has an expiration date. Label says to freeze it. I'm excited to try it out. Besides the new surface mount multiplexer, there's also some surface mount ceramic caps and a linear regulator. I'll get a handle on the easy-to-solder components first.
You have the much older OM602 engine so a definite NO!Does this works with only K line? My sprinter doesn't even have a obd2 port :'(
Now she is crying thanks to you 😐You have the much older OM602 engine so a definite NO!
It doesn't even work with the OM611 and OM612 engines.
