Where are you measuring the 16-volts, from the discharge or charge post?
I measured at the terminal to the right of the negative terminal, I don't know which that is, the voltage there reads the same as the output terminals on the inverter/charger. I also measured voltage at the terminal to the left of the negative terminal, I can't remember now but it was either the same or zero (my only excuse is that I'm in severe pain when crawling under the van). I will check it again.Where are you measuring the 16-volts, from the discharge or charge post? Unlikely from the charge post, the inverter is directly connected to the charge post (if rewired) via 4/0 wire, and you mention reading 14-volts at inverter DC terminals, that is a huge voltage drop. Also, the AGM kicker wilasl be boiling over at 16-volts.
If the Ecotrek discharge post is reading 16-volts, then likely that is the culprit why the charge relays are offline. You have to trace the inverter DC connections if it’s indeed rewired to the Ecotrek charge post as recommended by RT, this prevents backdoor charging of the Ecotreks resulting to overcharging.
I haven't seen where the solar power ties into the system. I ran through the functions of the MT50 meter on the controller, I thought it would let me shut the system off but it doesn't. I did verify all the settings and I noticed that the battery voltage reading on the MT50 meter is lower than what I measure at the batteries.That may be part of a design problem. Inverter/charger combo units share the same connection to the battery, so they can't make any distinction between a charge and discharge port. But the battery's BMS thinks otherwise.
Which port did the solar get connected to?
The 16 and 14V readings were with the system unloaded and loaded respectively.Where are you measuring the 16-volts, from the discharge or charge post? Unlikely from the charge post, the inverter is directly connected to the charge post (if rewired) via 4/0 wire, and you mention reading 14-volts at inverter DC terminals, that is a huge voltage drop. Also, the AGM kicker will be boiling over at 16-volts.
With the batteries switched off and the inverter/charger on I'm getting 17.1V at the charge terminal on the Ecotrek battery and 0 at the discharge post. When I turn the inverter off the voltage at the charge terminal drops to 16.4V. The solar charger shows 13.4V at the battery with very low amperage since it was almost dark. Logic tells me that the 16.4V must be coming from the battery although the onboard voltmeter shows 12.9V when I turn the batteries on. The DC accessories in the coach seem to work normally, I'm assuming that they will draw the battery down to it's cutoff point since I don't show charging voltage on the onboard meter (unlesss I hold the reset button down). It seems that that Roadtrek rewired the system to current specs and the system worked fine for 5 years after they last worked on it.Where are you measuring the 16-volts, from the discharge or charge post? Unlikely from the charge post, the inverter is directly connected to the charge post (if rewired) via 4/0 wire, and you mention reading 14-volts at inverter DC terminals, that is a huge voltage drop. Also, the AGM kicker will be boiling over at 16-volts.
You've exceeded my electrical knowledge by bringing up MOSFETs.If you charge a battery through a MOSFET (the internal switch inside a BMS) and then disconnect the charger, what you measure at the battery input is the battery voltage minus one diode drop (about 0.7 volts) from voltage back feeding through the body-drain diode that is part of the MOSFET.
In other words, the MOSFET is not a perfect on/off switch and your measurements of 17.1V and 16.4V make perfect sense.
But that leads me to a more serious question with potential safety issues. Is your lithium battery pack really getting charged to 17 volts? If so, your charger is providing an overvoltage and your BMS is not doing its job.
Double check one thing before we go any further. What is the voltage
between the battery negative post and the vehicle's chassis ground? You might just have a bad ground strap.
I was using the center battery post.You're exactly right, there should be very little voltage there. Even with a current shunt, there should only be about 0.1 volts or less. But if there is more than that, then that explains your high voltage readings. You might be reading about a 13 volt battery in series with a highly resistive pathway to ground that creates an additional voltage drop (or voltage rise, in this case).
When you measured the battery charging input, what did you use for a negative reference on your meter? The battery post, or a more convenient chassis point?
Ecotreks BMS does not use MOSFETs, the charge and discharge terminals are switched by internal relays.
I/m waiting for daylight to do the suggesting testing. meanwhile heres a pic of my inverter panel.What's the chance your charger got glitched into a higher voltage setting, and your BMS is doing exactly what it should do, that is, shut down when there’s too much input voltage.
This is the reason I design in redundant safety layers to lithium batteries. All it takes is one Single Event Upset to change a software setting, and then your system ends up doing something it shouldn't ever do.
But that doesn't explain the UHG overvoltage, unless it uses the same charge regulator.
I wonder what "AF" Hz means? I guessed it might be automatic frequency, I'm also confused by the sine wave directed at the battery, I guess that indicates the charger?That shows you're in bypass mode and shore power or UHG is going straight to your outlets through the internal transfer switch. .
A couple odd things I see; It isn't saying 60 Hz line frequency, but rather "AF" Hz. Also, it thinks you're at 100% charge, but only shows two bars with room for more
Is there another page to see your bulk/absorption/float voltage settings?
Getting another meter, preferably with a DC current clamp, would help here a lot.
This one is well priced:
I checked my meter by checking the battery of a car parked in the garage overnight. 13.2VKeep in mind that the AGM kicker battery is connected to the Ecotrek charge terminal; without a charging source (solar, shore, UHG), and with Ecotrek switched off, you are reading the AGM battery voltage. It is unlikely that the 12-volt AGM will hold a surface charge of 16 volts. It's possible that your multimeter's internal battery is low; many multimeters will produce a false high reading when its battery is low. Verify the multimeter reading by checking a battery with a known voltage.
With Ecotrek turned on and if properly working, you should get same voltage reading at the discharge and charge terminals against the battery negative post. A voltage drop at the DC house load could indicate a bad ground or poor connections.
Here's a simple way to see if the Ecotrek charge terminal relay is working and if the inverter is wired to the Ecotrek charge side. Without shore and with engine off, switch off both Ecotreks, then power on the inverter. If the inverter powers on, then it’s wired into charge side and it is being powered by the AGM battery. At this point, the 3kW inverter can supply a small load and will shut down from low voltage when a larger load is applied (ex: microwave).
With the Ecotrek turned on, see if the inverter can now power the same high demand appliance (ex: microwave); if so, the Ecotrek charge relay is operational and not in protection mode. At this point, the Ecotrek is powering the inverter via the charging terminal relay. If the charge relay is indeed operational, the Ecotrek should be getting charge current from any of the available chargers (UHG, solar, and shore). I hope that makes sense to you.
FYI: Ecotreks BMS does not use MOSFETs, the charge and discharge terminals are switched by internal relays.
