I recently turned on my 2 Ecotrek 200s in my 2017 CS Adventurous in anticipation of my winter migration (and cold weather). They turned on properly and the showed 13 volts, which is where I keep them while stored.
My problem is that neither Ecotrek will charge past the 13V level unless I'm holding the reset button on the control switch down. I'm getting full charging voltage from both the underhood generator and the inverter/charger but it doesn't show on the volt meter unless I'm holding the reset button down, when I release the button the voltmeter drops to the 13V that I started with.
The inverter seems to work normally. I'm currently trying to charge one bank at a time to see if I have one bad battery but it seems that both batteries are behaving the same. It seems unlikely that both batteries have failed the same way simultaneously.
I can't find an explanation of exactly what the reset buttons do, obviously they power a relay but maybe that's too simple. Can anyone explain it?
I'm planning on leaving in a few days and I don't expect I could get any professional help in that time. My current thought is to start driving and plug into shore power every night but starting a trip with an obviously malfunctioning system certainly goes against my grain.
Any advice or comments will be appreciated.
