V30 Low Roof Trim Panels
depark
2022 2500 4x4 LR
I tried the search function but couldn't find what I'm looking for. I have a 2022 144 Low Roof Sprinter and I'm looking for the part numbers and schematics for the plastic interior trim panels. Because I live in Canada and wanted a low roof van for my mobility conversion, I had to order it as a cargo with all the rear windows installed. Now I'm looking for the interior finishings. I have found some of the parts on https://www.mbonlineparts.com/ but I don't believe that they carry all of them plus all the parts are intermixed with different lengths and heights. It gets confusing really quick.
The parts I need include all the window trim pieces, upper rear door window trim, B pillar trim and all the rear headliner parts/pieces. I know it's a long list but hopefully someone has a list in part or complete.
Any help would be greatly appreciated.
Cheers
Darryl
depark
2022 2500 4x4 LR
Here's the area's I'm asking for and the ceiling.
B-Pillar trim
Top of rear doors window trim and D-pillar around rear doors
Passenger side window trim
Drivers side window trim
Cheers
Darryl
RVBarry
2023 AWD 170 DIY CamperVan
Hi, see if you can find a VIN for a VS30 144 low-roof passenger van; then the MB parts dept can look up all those pieces.
A little more info at
A lot of people sell their ceilings here, and sometimes D-pillars, but the window trim is more rare.
Afunkymonk
Cheers
Darryl
I am currently having my own van converted for accessibility, however, I ordered the ceilings and factory luxury panels from order. Anyway, here is part numbers for you:
Ceiling panels–
906-690-25-50 7Q96 - Center Rear with Sliding Door Right
906-690-49-50 7Q96 - Rear Section without Roof mounted air conditioning
906-690-30-50 7Q96 - Rear/Back Section (in front of Rear Doors)
201-990-02-92 9051 - Expansion Rivet (two required)
000-998-37-21 9051 - Cover Cap (four required)
907-695-23-00 - Roof Dampening (two required)
008-988-09-78 - Roof lining mount (fourteen required)
000000-000467 - Tapping Screw, Roof Lining Mount (two required)
907-545-77-00 9051 - Bracket, Upper EDW
008-988-09-78 - Clamp, Roof Lining (twelve required)
906-983-01-98 - Filler Material, B-Pillar (two required) and Center Roof (two required) (four in total)
907-695-19-00 - Dampening, Right Center
907-695-39-00 - Dampening, Left Center
907-695-20-00 - Dampening, Center
Potentially may require the joining flap between the front ceiling and center ceiling, I am unable to see it in the photos, this is:
906-690-04-07 - Flap, Front Ceiling
641-990-01-92 - Expansion Rivet, Cover (three required)
000-990-93-25 - Thread Rolling Head Screw, 5x15.5 (four required)
002-997-46-86 9051 - Grommet, Trim Mount (two required)
906-695-05-14 - Bracket, Left Cover
906-695-01-33 - Spacer Piece, Left Cover
002-990-94-97 - Rivet, Holder Mount (two required)
906-695-06-14 - Bracket, Right Cover
Rear Doors–
There is no upper door window panels available for Low Roof Sprinters, Mercedes-Benz couldn’t be bothered to make them, I had been looking as well. There is the potential to buy the High Roof versions and trim them down to size.
Sliding Door Right (T16)–
907-730-13-00 9051 - Trim, Lower (for manual door) or;
907-730-32-00 9051 - Trim, Lower (for electric door)
000-991-86-98 - Cover Clip (twelve required)
001-991-70-98 - Trim Clip (two required)
907-989-01-00 - Adhesive Film, Front Right
907-989-02-00 - Adhesive Film, Rear Left
906-631-06-08 - Cover, Sliding Door (for electric doors)
000000-000452 - Tapping Screw, Cover Mount, 4.2x9.5mm (for electric doors, four required)
There is no upper door window panels available for Low Roof Sprinters, Mercedes-Benz couldn’t be bothered again to make them, I had been looking as well. There is the potential to buy the High Roof version and trim it down to size as well.
Window Pillar Panelling–
LEFT
906-692-10-02 9051 - Trim (Panelling), Left from B-Pillar
906-692-24-02 9051 - Trim (Panelling), Upper Left Front
906-692-23-02 9051 - Trim (Panelling), Lower Left Front
906-692-08-02 9051 - Trim (Panelling), Left C-Pillar
906-692-35-02 9051 - Trim (Panelling), Upper Left Rear
906-692-37-02 9051 - Trim (Panelling), Lower Left Rear
906-692-13-02 9051 - Trim (Panelling), Left Rear from D-Pillar
906-692-64-02 9051 - Trim (Panelling), Lower Left, C-Pillar
906-692-07-22 9051 - Cover, C-Pillar, Lower Left
906-692-13-22 9051 - Cover, C-Pillar, Left
906-998-00-50 9051 - Stop Plug, Left Guide Rail (under window in rear left (circular holes))
RIGHT
906-692-52-02 9051 - Trim (Panelling), Right C-Pillar
906-692-36-02 9051 - Trim (Panelling), Upper Right Rear
906-692-38-02 9051 - Trim (Panelling), Lower Right Rear
906-692-06-02 9051 - Trim (Panelling), Right Rear from D-Pillar
906-692-66-02 9051 - Trim (Panelling), Lower Right, C-Pillar
906-692-07-22 9051 - Cover, C-Pillar, Lower Right
906-692-13-22 9051 - Cover, C-Pillar, Right
906-998-00-50 9051 - Stop Plug, Right Guide Rail (under window in rear right (circular holes))
D-Pillar Panelling–
LEFT
910-690-24-00 9051 - Trim (Panelling), Left D-Pillar
906-692-08-22 9051 - Cover, Lower D-Pillar with ventilation (four required); or
906-692-09-22 9051 - Cover, Lower D-Pillar without ventilation (four required)
001-991-76-70 - Clamp, Left D-Pillar Trim (four required)
094-991-14-00 - Expansion Rivet, Left D-Pillar Trim (five required)
907-693-01-00 - Cover Trim
RIGHT
910-690-25-00 9051 - Trim (Panelling), Right D-Pillar
001-991-76-70 - Clamp, Right D-Pillar Trim (four required)
094-991-14-00 - Expansion Rivet, Right D-Pillar Trim (five required)
Lower Rear Interior Luxury Trim Panelling (under windows to floor)–
LEFT
907-692-65-01 9H56 - Trim, Sidewall, Left Front (with Rear Speakers); or
907-692-64-01 9H56 - Trim, Sidewall, Left Front (without Rear Speakers)
907-692-80-00 9H56 - Trim, Sidewall, Left Wheel Arch (with Rear Speakers); or
907-692-77-00 9H56 - Trim, Sidewall, Left Wheel Arch (without Rear Speakers)
000-991-61-02 - Fastening Clip, Trim, Left (thirty eight required)
247-820-78-02 - USB Multimedia Connection Unit (three required)
907-823-00-00 9051 - USB Port Cover (three required)
RIGHT
907-692-92-00 9H56 - Trim, Sidewall, Right Wheel Arch (with Rear Speakers); or
907-692-89-00 9H56 - Trim, Sidewall, Right Wheel Arch (without Rear Speakers)
000-991-61-02 - Fastening Clip, Trim, Left (twenty required)
247-820-78-02 - USB Multimedia Connection Unit (one required)
907-823-00-00 9051 - USB Port Cover (one required)
B-Pillar Panelling (replace existing)–
907-690-14-00 9051 - Trim, Left B-Pillar
907-690-36-00 9051 - Trim, Right B-Pillar (with handle but manual sliding); or
907-690-37-00 9051 - Trim, Right B-Pillar (with handle for electric sliding)
Your existing trim clips should suffice for the above replacements, just remove them carefully.
depark
2022 2500 4x4 LR
Ceiling panels–
Rear Doors–
LEFT
RIGHT
D-Pillar Panelling–
LEFT
RIGHT
LEFT
RIGHT
OMG You Rock!!!!!!!! Thank you so much. This is exactly what I was looking for.
Cheers
Darryl
Afunkymonk
Cheers
Darryl
You're welcome.
You might want to consider changing the front headlining/ceiling to match the rear ceilings, as the one in the van as standard has a slightly different color, however, it's up to you.
sonvan
Curious did the B-pillars you en
Cheers
Darryl
Darryl did you ever get the correct B pillars? What was the part#? I am tyring to swap out my half naked cargo B pillars with the fully wrapped Bpilars with the D ring cut out at the bottom. Also any other part#'s that you ended up ordering. That was a long list that funkymonkey priovided, I doubt you got all of that?
sonvan
Funky monkey list above states:
The MB parts sites says for my 2024 low roof to go with 907-690-37-00 9051 - Trim, Right B-Pillar (Standard roof without left sldg door.). HOwever I dont have elec door. So from FnkyMnky list I would then go with "....36..." However I called MB and gave them a VIN for a 2026 crew with lo roof and they gave me "......34...." Anyone can confirm the diff b/w these ??
depark
2022 2500 4x4 LR
Sorry Sonvan, I have looked for the info but can't find what I actually got in the end. I can't remember if those numbers were correct.
sonvan
So I think I may have figured it out... For the passenger side B pillar with no cargo wall it appears it comes in 3 variants ,I have no clue how someone is supposed to know this because MB parts just ask you for a VIN for a specific vehicle and just tells you what that came with. I am thinking the "34" variant missing from the list above is basically 907-690-34-00 9051 - Trim, Right B-Pillar (w/out handle manual sliding). WIth that said I am probably going to order the 36, thanks again to this forum because if not I may have ordered the incorrect 37 B pillar as that was what the MB parts site said.
