Hodakaguy
Let's finish out that interior trim!
Stopped in at Terrawagen and picked up one of Eric's "Tidy Trim" kits. We're running a custom interior in our 2017 sprinter and for the last several years the trim around the B-Pillars and over the sliding door has remained unfinished. I keep saying I'm going to tackle this project but never find the time since making a professional looking trim piece for these areas is a royal pain and I have way to many hobbies fighting for my time lol. Luckily for myself and everyone else Eric is now making a Tidy Trim Kit designed for just these areas! The kit says for 2019 and up but fits the older NCV3's as well. The kit is composed of ABS plastic molded pieces that fit like a glove and it's available with or without a drivers side trim ring.
Once back home I set to installing this setup ahead of the upcoming Adventure Van Expo in Hood River OR.
The kit as it comes from Terrawagen in all it's glory.
Here's the section of missing trim around my sliding door.
First up I needed to remove the Mule bag and remove the upper panels in the van.
The kit comes supplied with these barrel nuts that screw onto the existing factory door hardware, the center trim piece will attach using two of these barrel nuts. These rest of the trim pieces are compression fit.
Testing the center trim piece for fitment.
Since I utilized/retained my factory passenger plastic trim in my build I'll have to make the new trim piece tie into my existing trim. The Terrawagen kit comes with trim pieces that go all the way to the floor and most people will use the entire kit. Here I'm marking out where I will cut the upper trim piece to line up with the L-track.
And....Cut.
Test Fitting.
With the trim piece temporarily installed I could take measurements and see how much I will have to shorten the panel. With the measurements in hand I carefully peeled the existing fabric/foam back, cut the panel down to size then used some 3M90 to re-wrap the panel.
Continued Below....
And....Cut.
Test Fitting.
Continued Below....
