Did you do the rear lights as well if so do you have the part number for the LED rear tail lights?Complete! OEM 2019-2022 Mercedes Sprinter LED Headlight Left and right OEM @ ebay
Original Kufatec Cable LED High Performance Headlight Code LG7 for Sprinter @ kufatec
9075405487Rear Sensor @ MercedesBenzStar.com
LED Headlight and Tail Light Change Programmer 2019 - 2023 Sprinter @ mid city engineering
1 1/2 hour install dyi
Error free.
NumberPart NamePriceQuantityTotal
9108205400Tail Lamp Assembly
9108205500Tail Lamp Assembly
Plug and play. / only left fog light turen on per state law.
You are awesome so i guess I don't need to pay for programming i can just throw these in I purchased
some on ebay they look amazing but they are aftermarket they are giving me error codes for the right hand side
I need to return them since they are driving me insane they work but the error codes are annoying.
By the way our head lights are amazing i am going to try upgrading mine as well with your parts list
how hard was it to install the sensor?
Do you know where i can find instructions on installing the sensor was it hard to do?LED Headlight and Tail Light Change Programmer 2019 - 2023 Sprinter @ mid city engineering
1st= 9075405487Rear Sensor @ MercedesBenzStar.com
2nd= install the sensor as image # 1, then use marker to mark the hole.
3rd = remove the sensor then drill the 2 holes
4th = put rivet nut in the holes
5th= then install the sensor back in place.
Mine already have the front.
Note - image are not mine, screen shot on another tread from this site.
That’s lit!Final result. Thanks for this site.
