StinkerBeanMonday
Does anyone have a paint match for the gray lower plastic parts. Either spray can or actual factory paint code?
I would guess a paint shop could go scan it in the parking lot then sell you a few rattle cans??Does anyone have a paint match for the gray lower plastic parts. Either spray can or actual factory paint code?
I thought of that as well. some of the paint is faded more than others so no matter what I do there will not be a perfect match. I found some Rustoleum Smoke Grey that is quite a good match (very good actually). Maybe I'll just take a piece of the plastic into Walmart and see if there is anything closer.I would guess a paint shop could go scan it in the parking lot then sell you a few rattle cans??
It does appear to be gelcoat (grey over black plastic). I would have assumed paint. Any particular reason to spray gelcoat over plastic? I never knew this was a thing.Are those gray plastic panels painted or is it a colored gel coat? Mine appear to be gel coat over black panels. If you paint them,
surface prep on the panels will be critical for good adhesion.
Mine have held up very well over the 17 years I’ve been the owner. Would paint have held up as well as the gel coat? I’m not sure. What I do know is that any undercarriage steel added and painted by Winnebago has rusted, and this is in an inland California area.It does appear to be gelcoat (grey over black plastic). I would have assumed paint. Any particular reason to spray gelcoat over plastic? I never knew this was a thing.
