cahaak
Hi,
In the short time I've had my sprinter I managed to go through every post in the T1N section and what I have done is to creat a Word document that has hyperlinks to all of the various threads that I have found useful. It includes the standard maintainence threads as well as a bunch of other useful threads. I find it very useful and fast for looking things up.
So, here it is -
Chris
--- List from PDF ---
Glow plug thread with module modification
Hitch information
Oil change information
Driver foot heater tube modification
Crankshaft sensor replacement
https://sprinter-source.com/forums/showthread.php?t=40927
showthread.php?t=92092
Video: https://sprinter-source.com/forums/showthread.php?t=76487
Transmission drain and service
Brakes:
Replacing the FOB battery
https://sprinter-source.com/forums/showthread.php?t=8109
Glow plug testing:
https://sprinter-source.com/forums/showpost.php?p=5232&postcount=17 - part of a long and very informative thread on glow plug replacement
Air Filter change
https://sprinter-source.com/forums/showthread.php?p=60366#post60366
cabin filter change
https://sprinter-source.com/forums/showthread.php?t=2374
Air vent pin fix
https://sprinter-source.com/forums/showthread.php?t=4242
Rear AC idle cut out
https://sprinter-source.com/forums/showthread.php?t=6607
Broken Hood release and replacement
https://sprinter-source.com/forums/showthread.php?t=17545
Panel removal and retainer clips
https://sprinter-source.com/forums/showthread.php?t=1648
https://sprinter-source.com/forums/showthread.php?t=69873&highlight=panel
Starter motor replacement
https://sprinter-source.com/forums/showthread.php?t=31076
...Test of the Starter electrical
... https://sprinter-source.com/forums/index.php?threads/86528/#post-891025
Alternator Replacement
https://sprinter-source.com/forums/showthread.php?t=26087
https://sprinter-source.com/forums/showthread.php?t=45516
Serpentine belt replacement
https://sprinter-source.com/forums/showthread.php?t=5478
Serpentine belt tensioner
https://sprinter-source.com/forums/showthread.php?t=18310
Recirculating pump replacement
https://sprinter-source.com/forums/showthread.php?t=13404
...If you want to repair the recirculating pump https://sprinter-source.com/forums/showthread.php?t=13546
Radiator cleaning
https://sprinter-source.com/forums/showthread.php?t=12434
Water pump:
Aux battery info
https://sprinter-source.com/forums/showthread.php?t=263&highlight=battery
https://sprinter-source.com/forums/showthread.php?t=2674&highlight=battery
OM647 O2 sensor cleaning (OM612 doesn't have one)
https://sprinter-source.com/forums/showthread.php?t=5038
Antenna replacement
https://sprinter-source.com/forums/showthread.php?t=5896
Trailer wiring harness
https://sprinter-source.com/forums/showthread.php?t=7489
https://sprinter-source.com/forums/showthread.php?t=6880
https://sprinter-source.com/forums/showthread.php?t=4444
Fuel filter
https://sprinter-source.com/forums/showthread.php?t=7537
https://sprinter-source.com/forums/showthread.php?t=2318
Fuel filter - OM612 2001-2003 specific
OM612 fuel rail pressure control valve rebuild
https://sprinter-source.com/forums/showthread.php?t=29457
OM612 clear line replacement
https://sprinter-source.com/forums/showthread.php?t=58974
OM612 engine harness replacement
https://sprinter-source.com/forums/showthread.php?t=70273&highlight=harness
Headliner clips
https://sprinter-source.com/forums/showpost.php?p=10988&postcount=1
Winter Grill cover
https://sprinter-source.com/forums/showthread.php?t=8852
https://sprinter-source.com/forums/showthread.php?t=663
Dome light replacement bulbs
https://sprinter-source.com/forums/showthread.php?t=8756
Heater control explanation
http://www.sprinter-source.com/forum/showthread.php?t=4759&highlight=temperature
various sprinter PDF files in this thread
https://sprinter-source.com/forums/showthread.php?t=6344
Post about changing tire sizes to 215/85/R16
https://sprinter-source.com/forums/showthread.php?t=3064
Stepwell plug screw locations
https://sprinter-source.com/forums/showthread.php?t=6899
Seat covers and floor mats
https://sprinter-source.com/forums/showthread.php?t=10553
Rear seat belt cover and seat belt buckle replacement
https://sprinter-source.com/forums/showthread.php?t=6295
Front Blower/fan motor resistor replacement
https://sprinter-source.com/forums/showthread.php?t=4221
https://sprinter-source.com/forums/showthread.php?t=8262
Front heater/AC fan removal and brush replacement
https://sprinter-source.com/forums/showthread.php?t=9252&page=3
Transmission pan plug removal and number.
https://sprinter-source.com/forums/showthread.php?t=6271
Radiator swing out: If your T1N has AC and you need access
Radiator Push out technique (w or w/o AC)(for any of the above except harmonic balancer)
https://sprinter-source.com/forums/showpost.php?p=49104&postcount=1
Harmonic balancer issues
https://sprinter-source.com/forums/showthread.php?t=5226
Drone noise at around 70 mph
https://sprinter-source.com/forums/showthread.php?t=1420
Subwoofer
https://sprinter-source.com/forums/showthread.php?t=33&highlight=subwoofer
Cargo lamps from the aux battery
https://sprinter-source.com/forums/showthread.php?t=2252
Front shocks/struts
https://sprinter-source.com/forums/showthread.php?t=2839
https://sprinter-source.com/forums/showthread.php?t=28362
Rear shocks
https://sprinter-source.com/forums/showthread.php?t=4865
Rear AC cover and painting it
https://sprinter-source.com/forums/showthread.php?t=1862
Armrest part numbers
https://sprinter-source.com/forums/showthread.php?t=1410
Swivel shades and overhead storage
https://sprinter-source.com/forums/showthread.php?t=1495
Sliding door latch (not the handle)
https://sprinter-source.com/forums/showthread.php?t=14026
https://sprinter-source.com/forums/showthread.php?t=2250
Door adjustment - slider and front doors
https://sprinter-source.com/forums/showthread.php?t=7110
Sliding door handle
https://sprinter-source.com/forums/showthread.php?t=14009
Front door cable clip:
Rear Axle U-Bolt retorquing
https://sprinter-source.com/forums/showthread.php?t=55366
Auxiliary Heater
...D2 Airtronic installed in rear
...Espar thread
....https://sprinter-source.com/forums/showthread.php?t=2812&highlight=espar
....https://sprinter-source.com/forums/showthread.php?t=2178
...Wiring Espar heater to run from a switch and adding a timer
....https://sprinter-source.com/forums/showthread.php?t=668
....https://sprinter-source.com/forums/showthread.php?t=601
Windshield wiper arm replacement
https://sprinter-source.com/forums/showthread.php?t=9487
Lumbar bulb rebuild: https://sprinter-source.com/forums/showthread.php?t=5574
So, here it is -
Chris
Hitch information
Overview of what you will be looking at: https://sprinter-source.com/forums/showthread.php?t=7605
Instructions: https://sprinter-source.com/forums/showthread.php?t=2557
Transmission valve body maintenance: https://sprinter-source.com/forums/showthread.php?t=2476
Additional background info: https://sprinter-source.com/forums/showthread.php?t=6704
Dip stick and reading it: https://sprinter-source.com/forums/showthread.php?t=14804
Brakes:
- Front Rotors and brakes
https://sprinter-source.com/forums/showthread.php?t=7593 - Rear Rotors and brakes
https://sprinter-source.com/forums/showpost.php?p=606123&postcount=8 - Caliper boot and seal replacement
https://sprinter-source.com/forums/showthread.php?t=63908 - Steel Brake Line replacement (no OEM lines are available - must DIY)
https://sprinter-source.com/forums/showthread.php?t=26307 - Brake hose replacement https://sprinter-source.com/forums/showthread.php?t=83505
Glow plug testing:
Air Filter change
cabin filter change
Air vent pin fix
Radiator cleaning
Water pump:
OM612 (2002-2003): https://sprinter-source.com/forums/showthread.php?t=80339
OM647 (2004-2006): https://sprinter-source.com/forums/showthread.php?t=6228
Aux battery info
Antenna replacement
Fuel filter
- Priming tool and instructions https://sprinter-source.com/forums/showthread.php?t=57440
- Testing by-pass valve for air leaks: https://sprinter-source.com/forums/showthread.php?t=57455
- Change fuel filter to one without water sensor: https://sprinter-source.com/forums/showthread.php?t=20104
- Test to isolate source of leak upstream or downstream of the supply line into filter: https://sprinter-source.com/forums/showthread.php?t=50403
Headliner clips
Winter Grill cover
- water pump
- OM612 clear line replacement
- Harmonic Balancer
- Serpentine belt tensioner and idler pulleys
Subwoofer
Front shocks/struts
Rear shocks
Sliding door handle
Front door interior handle broken cable tie
Trying to open the front door as normal - and that bad tactile feeling that something is breaking while pulling the front door lever from the inside. Finished off the day getting out of the van from the passenger side. Once home, I removed the door panel per instructions from here...
sprinter-source.com
Auxiliary Heater
...Espar thread
