RearViewMirrow
2022 Mercedes Benz 4WD Custom Conversion
I'm curious if anyone can help me with this question.
The last diesels that I owned were a 2003 and a 2005 Dodge Dually with a Cummins engine. Back then, there was a plug that ran out of the front grill that you could plug in when the temps outside were cold to keep the grid heater inside the engine warm (Cummins didn't use glow plugs back then). If you didn't have access to a plug to heat the grid heater, you just turned the key to "accessory" to activate the grid heater until the light went out then it was fine to start the engine.
The Sprinter obviously doesn't have a plug in the grill to plug in during cold weather. But since mine is a 2022 it comes with a push button start. So far it has only gotten down to the low 20's here but by the time that I "usually" start it up, the temps have usually raised up to the mid 30's. Since it's a push button start I've been doing the same thing that I did with my Cummins. I'll push the start button 2 times without my foot on the brake. I can see the glow plug indicator light up but it goes off within a few seconds. Then I just start the van and let it idle for a min or so. I've not tried to start the van (yet) when the temps are well below freezing.
What is the correct procedure for activating the glow plugs in very cold weather with a push button start? Am I doing it correctly by essentially putting it accessory mode and letting the glow plugs cycle until the light goes off? I haven't really had a chance to test this out since I haven't started the van in below freezing temps "yet". That will change soon.
