I’d imagine at the end of an evening after a long day that would wake a guy right up!
And remind one that, indeed, they have a room temperature IQ.I’d imagine at the end of an evening after a long day that would wake a guy right up!
Just be carful with home adapters on these fuel bottles. I was running a portable fire ring that was meant to use 20 pound tanks with 1 pound bottles..everything was going along great.
But when I wanted to disconnect the 1 pound bottle it split at the connection between two adapters and came loose instead of the actual bottle. This left unregulated propane spewing out, hitting the hot fire ring, and made a makeshift flamethrower.
Needless to say, I was a bit concerned, grabbed the flaming bottle and threw it towards a clearing in the pasture. I’m not doing that again!! I got very lucky..
Thanks for posting that. 👍🏽I've been looking for a while for a portable, self-contained sink like this since I don't have a proper water system and my build is very modular / noncommittal. Only thing that is a big downside is how small the fresh and waste tanks are. "Mysteriously" popped up on my Instagram...
BOXIO - WASH: Your portable camping sink
Whether for washing hands after using the toilet, the small wash-up in between or brushing your teeth in the evening. The BOXIO - WASH is the ideal camping sink for your trip. Order now!myboxio.com
Seriously can't believe how hard something like this is to find...Thanks for posting that. 👍🏽
That’s actually a good idea for a temp build or work van/occasional weekender.
It‘d be nice to see a 12v usb pump version and add on supply and grey water tanks to expand the system.
I’m sure those can be diy’d as add ons.
Seems like something that’d be quite useful for the jeep/tacoma overlanding/camping crowd.Seriously can't believe how hard something like this is to find...
I'm actually looking for the old fashions sprayers that just mounted in the hood, or possibly making the kind that fits under the hood and is just flattened brass tubing.Not sure this post applies to this thread but I recently snagged the wiper arm washer fluid spray head with a rag while wiping down the windshield and broke it. I failed in several attempts with super glue, gorrilla glue, etc. to try and fix it but the plastic used simply will not bond. I stopped into the dealer and was quoted $38 for what is likely a 10 cent piece to make in quantities. AliExpress has them for under $4 for quantity 2. I doubt these are identical to the original and may have only two spray holes not 3 but I can make this work.
make your own.I've been looking for a while for a portable, self-contained sink like this since I don't have a proper water system and my build is very modular / noncommittal. Only thing that is a big downside is how small the fresh and waste tanks are. "Mysteriously" popped up on my Instagram...
Yes, I've considered that and like working with 8020. But also takes time to plan and build, and it might be a little harder to build something very compact and movable.make your own.
i finally made something to wash my hands and draw fresh water. i grew tired of the bulky 3gal container banging against the side and me dribbling water on the floor.
build one like the boxio and will probably lead you to a better “final build”.
my cost was: tank + basin + pump = $120
although 20series extrude and fastenrs was extra. but its my spec versus versus having to work with a boxio design. pump is battery powered.
Replaceable beauty rings to make sure our fake bead locks stay looking good.. oh boy!Outside Van has a new rear step and wheels, and an under-mount replacement tire carrier to fit larger tires.
(Thanks to @dddrks for mentioning)
The wheels have an interesting feature, a removable ”rock ring.”
”the removable rock ring allows you to easily replace any damage or scuffing down the road. Replacement rock ring sold separately.“
View attachment 273443View attachment 273444View attachment 273445View attachment 273446View attachment 273447![]()
METALWORK
All the quality product Outside Van is known for. The Outside Van Shop is a one-stop location to purchase everything you need to your van life adventures.shop.outsidevan.com
Yeah I’m sure John at Owl had some choice thoughts / words when he saw that step.Similar to the OWL step. Looks nice, pro and con with each.
Yup. So if you knee wack it the OV one is better but if you drag it off road the OWL won’t act like a shovel. And the OWL looks like an F35 tail so there’s that too.Imnsho the Owl one looks slightly better, but the Outside Van version has a turned down edge so as to reduce the chance of a not so nice shin or knee contusion.
Unless you have to back down…Yup. So if you knee wack it the OV one is better but if you drag it off road the OWL won’t act like a shovel.
