Hi Guys,
Trying to get rid of the ABS, EDC, EDS and "burnout light" on the dash.
Scan tool always come up with RR wheel speed sensor. Replaced the wheel probe and wiring right to the module with no difference. I have cleaned terminals, etc in the ABS module, but still get the same issue. A signal from the RR wheel is as clean as the LR but it still brings up the same code. Van drives fine, but I have no cruise control or ABS.
Any ideas on where I can get a ABS Module? I believe it needs to be the exact part number or it wont communicate.
Mine is 0 265 950 137 which apparently is only fitted to the automatic vans.
That is the part number on the bottom of the black ABS module, not the one on the alloy block of the ABS unit.
Urgently needing to buy one! I have tried lots of wreckers, etc but no luck so I am hoping a member may have one.
Thanks for any suggestions.
