jdcaples
Not Suitable w/220v Gen
In another thread, I saw someone recommend moving injector number 4 to a different cylinder to figure out if a problem followed the injector or the wiring.
There was no mention of injector classification. There was no mention of swapping injectors with the same injector classification identifier.
I was wonderng if injector classification is more "optional" in OM612s and OM647 Sprinters than my interpretation of the service manual on injector classification lead me to suspect.
In other words, can you just drop an injector into any OM647 or OM612 cylinder and go about your business w/o bothering with this classification procedure?
-Jon
From section 14 of a copy of the 2005 Dodge service manual PDF.
STANDARD PROCEDURE - INJECTOR
CLASSIFICATION
The classification of injectors into 3 classes
describes the quantity characteristic of the injector.
This will make it possible in the future to match the
engine software to the tolerances of the injector
within a more narrowly graduated range. Classification
can be clearly recognized, and assigned only by
means of a DRBIII.
Classified injectors can be recognized by the part
number and identification on the magnetic head (circle
with a number between 1 and 3 inside) (Fig. 9).
The number corresponds to the classification stage.
These general conditions equally apply if, as a
result of replacing an engine, carrying out repairs to
the cylinder head etc., the cylinder selective assignment
of the injectors or the engine control module
assignment may have changed. If proper attention is
not paid to the classification on these vehicles driveability
and smoking concerns could result.
If an injector is replaced, it is then necessary to
assign the classification number to the corresponding
cylinder with the DRBIII in the control module.
INJECTOR CLASSIFICATION PROCEDURE
(1) Turn ignition switch “ON”.
(2) Using a DRB III and select ENGINE then
MISCELLANEOUS.
(3) Select LEARN INJECTORS.
(4) Using the up and down arrows, scroll to the
appropriate injector.
(5) Using the right and left arrows, set injector to
proper classification.
(6) Once injectors are classified, cycle ignition to
complete.
-Jon
CLASSIFICATION
means of a DRBIII.
MISCELLANEOUS.
complete.
