Bill B.
Cool! I like that design.Tell me about this spare tire carrier
custom?
stock
install
pros and cons...
I like this one,
I need to get mine out from underneath
thanks
custom?
stock
install
pros and cons...
I like this one,
thanks
Yeah, the folks down in the southern hemisphere got all the good stuff, 4X4, Manual Transmission, Bull (Roo) guards, tire carriers, etc.Cool! I like that design.
They got a stick?! That’s not fair at all. Bull guards…. meh. I’d definitely pass on 4x4 though.Yeah, the folks down in the southern hemisphere got all the good stuff, 4X4, Manual Transmission, Bull (Roo) guards, tire carriers, etc.
Regards,
Mark
You don't know what you're missing. It's a blast. Unless of course strictly paved road is your thing.They got a stick?! That’s not fair at all. Bull guards…. meh. I’d definitely pass on 4x4 though.
I’m definitely an off-road guy and have probably driven some cat tracks I shouldn’t have. If I was endowed with the false sense of confidence that 4-wheel drive afforded… I’d be that idiot making headlines when he was finally found upside down in a ravine 10 years after the fact. It’s better for all considered that I test the limits within range of a tow truck.You don't know what you're missing. It's a blast. Unless of course strictly paved road is your thing.
Car companies figure Americans can't handle a stick. Our last vehicle with one is my Subaru. The southern dwellers got a diesel and the 6 speed and I think more ground clearance. I got the gasser and the very rare 6 speed, no longer available.They got a stick?! That’s not fair at all. Bull guards…. meh. I’d definitely pass on 4x4 though.
I remember driving my 4x4 pickup with 4 speed around some corners, eating a big whopper and then my phone rang.drivers need to be scarfing burgers
It's a high-clearance DIY weld-together rear bumper kit (with spare wheel swing-out option) for the T1N Sprinter. Available from coastal offroad which are located in BC, Canada. I had it shipped to me here in the US. It arrives as CNC cut plates which you then tack together and weld.Tell me about this spare tire carrier
custom?
stock
install
pros and cons...
I like this one,
thanks
All my kids learned on a stick too. Saved a bunch when renting in Europe if you don't need an automatic. Still two other manuals left in the family.
Regards,
Mark
How do I go from the freight liner grill to the Mercedez one? Since one has a circle and my freight one is just flat?Nice work. The front end design on the T1N still looks good - the lines of the headlight shapes / the slight wrap around into the wings / the bonnet and grille etc.
My old T1N was built in 1999, so originally had the Type 1 front grille in your post above. The grille surround design changed to the painted perimeter version I think in 2003 - from memory - along with clear lens front headlights and a slightly revised in appearance rear lamp cluster. I retrofitted all that at the time, for a "facelift nose job". Pretty sure the bonnet vent changed as well, although I just kept the original.
Still have a green painted front grille trim on the inside of the garage door, plus another one that was polished and chromed one as per pic. It contrasted well with the dark body colour. Used to swap them around, surprising to think my spare one is twenty years old now.
Another one... stopped off for a break in south eastern France, somewhere in one of the national parks in between Monaco and Lyon.
That is a picture of a newer model Sprinter and it is aliexpress, so my answer is going to be no. If you buy them be prepared to eat them as shipping back will cost more than they cost, and they will be cheap plastic that no one will buy from you.Anyone know if this style will fit the T1N Ihttps://a.aliexpress.com/_mq403v1
The OEM hub covers for the T1n is just a round little center cap. If you want something that comes out to the lugs, you need Dodge or Freightliner.Anyone know if this style will fit the T1N Ihttps://a.aliexpress.com/_mq403v1
Look back at the first post on this thread. I explain how it's done there.How do I go from the freight liner grill to the Mercedez one? Since one has a circle and my freight one is just flat?
thanks!
