Some 2022 are not coming with rear sway bars. You can find a van that does and use its vin to get a stock one.
I run a upgraded Roadmaster.
My driving is mostly highway and having a nice sway bar does help. I notice the biggest difference when around trucks. The disadvantage is you lose some independent articulation in the rear end causing a rear tire to come off the ground sometimes when entering a dipped driveway.
from a 2022 144 hightop cargo with a sway bar vin W1W4EBHY7NT101216
A 907 320 79 01 Shock Absorber (x2)
N 910105 012019 Hexagon Head Bolt (x2)
N 000000 003276 Nut (x2)
N 910105 014020 Hexagon Head Bolt (x2)
A 907 320 72 02 Torsion Bar Complete (x1)
A 907 326 20 00 Bracket (x2)
*If buying the Roadmaster sway bar you don't need the torsion bar complete you just need the bracket. The problem is the brackets are no longer sold by themselves so you have to buy the torsion bar complete to get the bracket and just trash the bar itself when you replace it with the upgraded Roadmaster. (my shakle bracket that bolts on the axel that holds the sway bar from my 2011 did not fit my 2022. The 2022 is slightly wider.)
-Roadmaster's part number ( E Trailer has it) 1209-128
*A mounting kit is offered from E trailer but I don't know if it fits. Mount Kit 590064-00 (it does have nylon bushing and the stock has rubber on the drops. It is cheeper to run the stock linkage)
It is a bolt on job, A little grease, lock tight, torque wrench.
At purchase; My dealer checked off on the pre delivery mechanical inspection that my van had a sway bar. It did not. Ask for your pre delivery inspection cheek sheet.
