Oil sender unit?
TimT
I want to install a by-pass oil filter ( Trabold filter ) Aswith most by-pass filters you have to T into the oil pressure sender. So I guess my question is were is the sender?
Tim
talkinghorse43
Tim
Sprinter has no oil pressure sender - oil pressure is not sensed in any way.
tegimr
2003 Pass 140 289000 mile
The oil light indicates the oil level. Or should I say lack of proper oil level. :)
Hmmm. I'm certain that there's wisdom in that somewhere. We just 'trust' or hope :rolleyes: that there's pressure? Anyone know why they choose not to monitor and report on pressure?
Tim
abittenbinder
Doktor A (864-623-9110)
Tim
If you think about this, most "real" oil pressure warning light alerts are caused by low oil level-a damaging low level- a far lower level than would have already triggered our Sprinters warning light. Most "false" oil pressure warning light alerts are caused by faulty senders. Many times- oil pressure sender housings are the cause of substantial oil leaks. If a vehicle is equipt with a low oil level warning system- it substitutes sufficiently(and in the case of low oil level-substitutes more effectively) for most all-oil pressure warning issues. If you experience an extremly rare failure of the oil pump or its drive chain-you're likely doomed before you could react to a oil pressure idiot light or pressure gauge. Doktor A
