2012 Low Roof with SportsMobile (Fresno is now Field Van) Pop-top with 3.0L V6
Completed trip to and from Tucson (Oro Valley actually) after replacing the DPF bracket that attached to the transmission case. Also secured the scorched cable that goes to the DEF doser valve away from the exhaust - looking a a replacement for that wire. It has been a while since I have checked my mpg and was shocked to see it was 13.4 for my camper and we don't even have it loaded up, normally when loaded we get about18 mpg. So, I went back through my diesel receipts since June, and this is what I found for mpg.
Gals Miles MPG Comments
10.8 197 18.3 San Diego to Yuma
11.8 210 17.8 Yuma to Tempe
19.0 279 14.7 Around the Phoenix Valley
4.6 80 17.3 Still around the valley, top-up before heading to Santa Barbara
11.6 179 15.4 Ehrenberg AZ
20.2 352 17.4 Santa Barbara
16.4 271 16.6 La Jolla
7.0 79 11.3 La Jolla
15.2 265 17.4 Ventura
15.7 260 16.5 La Jolla
13.4 148 11.1 La Jolla
30.4 414 13.6 Del Mar - includes 10 $$ gals off I5 to get be to Del Mar
8.8 120 13.6 Del Mar
12.0 208 17.3 Yuma
19.1 324 17.0 Cordes Lake AZ
10.4 211 20.3 Tempe - trip up to Sedona
16.2 330 20.3 Tempe - includes trip to Cottonwood AZ
11.7 161 13.8 Tempe - trip to Oro Valley
The last entry was the first time I happened to check MPG which made be go back to June to see what was going on - varies greatly, need to understand why.
Almost 5,000 miles ago (now at 115,500) I replaced the wiring harness, heat exchanger, had injectors clean and tested (1 failed and was replaced & coded), glow plugs, serpentine and fan belts, idler pulleys, belt tensioner, alternator, water pump, radiator, oil filter, fuel filter, engine mounts and did an oil change.
I checked the engine air filter, so will replace that tomorrow. Went for a 30-mile drive and checked the brakes temperatures. all about 100+ degrees, so no sticking that I can tell. Will jack up tomorrow and inspect close up.
My DPF regens have not been happening till I get to 138% load and them it only regens down to above 30%. Attempted a driving force regen with Xentry, but it would not start because I could not get the pre DPF exhaust temp to 400 degrees, but after that I see that it reset the DPF level lower and I caught it at 6%. Be interesting to see at what % it starts the regen now.
We are setting off for South Carolina a week Monday so trying to get to the bottom of this. Will now start checking MPG with every fill-up to keep a close eye on it, starting with a short trip on Tuesday after air filter is replaced.
I have not had the AEM done yet, planning that for the new year.
Lance
12.0 208 17.3 Yuma
Lance
