Yes, thatʻs what Iʻd guess - that it shows Charging when the current is over some setpoint, say 4 amps - and when it drops below that, it shows Maintenance. IOW, itʻs a simple system where the charge current drops to zero as the battery voltage approaches the Trik-L-Startʻs output voltage - their charging curve says the output voltage is 13.5, so as the battery goes to 13.1, 13.2, 13.3, the current drops to zero. I hope I donʻt have to look at the lights now that itʻs in there - I mounted it under the passenger seat just above and behind the Sterling, and I have a tiny peephole under the seat so I can see the lights if Iʻm really curious. If I open the plastic access door, I can see all the Trik-L-Start and Sterling lights, and I can reach the 50A breakers on each side of the Sterling, and also the fuse in the Trik-L-Start line to the chassis battery - at the moment itʻs a 15A mini blade, because I had one. I hope thatʻs big enough - the Mega Trik-L-Start rev. F1 specs page says the max output is 10A, but the graph shows it can go up to 13 - go figure....
