Fresh Water Drain - Is there one?
TinManKC
‘’06 Resto-Mod
Hi we have an 06 G26. Looking to locate the fresh water tank Drain(s). Anyone found them on a G series? Thx!
greybush
not sure about the G26, but the G24 has 3 drain plugs located behind a removable access panel below the refrigerator.
TinManKC
‘’06 Resto-Mod
Thanks for the reply. The G26 has the heater below the fridge, no luck there.
greybush
Interesting. Well, I would assume that the drains are somewhere near the water tank itself which should be in the rear somewhere; under one of the benches or possibly under the raised floor in the rear? Maybe the drains are in behind the access panel that is below the bathroom door.
TinManKC
‘’06 Resto-Mod
I’ll look there. On the G26 the water tank is mounted crosswise between the rear wheel wells.
TinManKC
‘’06 Resto-Mod
Found them. The drains are on the drivers side, just outside the wheel wheel, between the wheel well. Drains are inside, under the driver side rear couch, and you need to remove the bottom cushion to access the drains, found under the rats nest if wires. Rear most drain is the fresh water tank, front 2 drains are plumbing system drains.
C919DEA2-46A2-4F99-ABFA-FEFEDC77BA36.jpeg8143E471-D61B-466C-8BC0-07946B89CC31.jpeg4013887A-06DF-4EFC-AA19-F5CD7528A78A.jpeg
