Please start another thread and post how you did it, or add to this thread:I've used the Espar Aux/Booster heater live data on my AP200. It's a pretty cool feature.
I recently bought some automotive relays to modify this unit into working as a pre-heater prior to starting my engine in -35C.
As for the AP200, I'd like to figure out a way to make it work without contacting the mothership prior to use.
I did have it working for an entire week, before it suddenly wanted me to login. I don't know what changed?
Wiring Heater Booster to run from Switch
Here is how to wire your Heater Booster to run from a switch. It also runs the fan so you can heat the engine and the inside at the same time with no 2 hour timeout. Works great for camping.sprinter-source.com
Regards,
Mark
It could be due to a firmware update:did have it working for an entire week, before it suddenly wanted me to login. I don't know what changed?
Autel AP200 screen shots + INFO
Re: Autel AP200 screen shots Edit: Instead of selecting "WD*** try selecting 901.6 When it asks to read your VIN there are two options. They are "Automatic Selection" and "Manual Selection". These terms are a bit misleading because naturally most of our minds think "transmission" when...sprinter-source.com
This can be a problem with using a (or "the") default file-copying app ... it may well try to verify the files as it goes by comparing the filename extension (the .jpg) with the "magic word" contained at the beginning of the file itself (JFIF for jpegs). If there's a mismatch, the copy program barfs. Some 3rd party file managers allow bypassing that check.I found the data files for this app on my phone and tried to back them up to my computer.
Part way thru the backup, an error message said that a file was of the wrong type and could not be copied.
I found out the hard way that you need internet access for this to work after I couldn't get it to work at a remote campsite in a state park. Vendor confirmed it. This is not on the packaging. I thought this was going to be a great solution but I'd return if I could but I bought it last November.
I'm getting the error message immediately when trying to sign in so there is something preventing it from even trying to connect, the message appears as I am pressing the button
Thanks, I tried that and they replied with telephone and email information for Mon-Fri tech support.If I were you, I'd go online and chat with Autel. I've done this a few times when I first got my AP200.
They were able to help me every time, at no cost. https://auteldiagnostictools.com/
I will but I was thinking they wouldn't be there till Tues due to the holidayYou might want to give them a call tomorrow. They never charged me anything for advice.
Mines down as well. Server communication failed message pops up when trying to log on.I will but I was thinking they wouldn't be there till Tues due to the holiday
