2018 sunseeker 2400mbs W sway bar towing and leveling help needed
spoonef
Hi all,
so have a 2018 sunseeker mbs 2400w and need advise on hauling. I plan to towing a 17 alum trailer with quad and side by side. total weight is 3500lbs. What do you recommend for:
air bags vs sumo springs or nothing
brake controller - plug and play
Thanks all appreciate your input and suggestions
Eric
Mike DZ
2016 View 24V (2015 3500)
Leveling - https://equalizersystems.com/ is what 90+ percent use.
next the RV wobbles a bunch at speed.
If the RV is wobbling then there is something seriously wrong - that is if wobbling means the same thing to us both.
Wobble - move unsteadily from side to side.
"The most common cause of vehicle wobbles in this speed range is a bent wheel or mildly out of round tire. Transmission and drive line issues can also show up in this range, but tires are the first thing to check. ... The most common cause of vehicle shakes at 50 mph or higher is tire balance."
