Since my wife and I do a lot of boondocking and because the Regency Ultra Brougham we now have seems to use a lot of power (just running the inverter eats up about 2 amps/hour even if you are not using the outlets, and none of the usb charging connections work without the inverter running, the macerator toilet uses a fair amount of power, and so on) I have thought seriously about adding another battery. The problem is that the battery box only has room for 2 type 31 batteries and so I would have to add a 3rd battery somewhere else and thus have to have the whole connection wiring redone to balance the distances. In addition my current BB batteries do not have any bluetooth connectivity so I would have no idea what was going on inside the batteries. Given all of that you comments are very interesting.
I have thought about replacing the 2 BB with 3 Lithium batteries that have their own bluetooth connectivity so I could see what was actually going on, but the cost has been an issue.
Exactly. I regret that I did not know enough about this when I first made the switch to Lithium. There are a lot of threads about upgrading from the OEM batteries to Lithium and they discuss a lot of issues, but I never saw this being discussed. The Victron SmartShut is much better than nothing, and I always have some idea of how much power I have left, but I have no idea what is going on inside the batteries - if they are balanced, if any of the cells might be going bad or even if one of the two batteries has failed.
