Old 12-22-2009, 12:57 AM   #1
jdcaples
Not Suitable w/220v Gen
jdcaples's Avatar
Default NAFTA NCV3 rear axle fluid, MPG impact, going multi-weight synthetic
Every once in a while I'll come across a forum posting - not necessarily Sprinter-Source (maybe, I forget), but some other auto-enthusiast site - talking about an increase in MPGs after changing axle fluid.
I noticed that Dodge is providing SAE 90 gear oil, marked with the word "Sprinter" on the label.
The 2007 owners manual lists several lubes which are appropriate for 2007 Sprinters
The Mobil Delvac Synthetic Gear Oil 75w-90 seems like a better fit to me. I'm not sure why; it just feels like it.
Here's the spec sheet: naxxencvlmomobil_delvac_synthetic_gear_oil_75w-90_80w-140.pdf
Is it still an "approved" fluid? Yes.
http://bevo.mercedes-benz.com/bevoli...hbegriff=235.8
The capacity of the rear axle is 1.8 litres. Dodge wants something like $30 per litre.
This site sells Mobil Delvac Synthetic Gear Oil 75w90 for USD $10.00 or so per litre.
The weather sucks right now for me to experiment, and probably for everyone looking at snow or temperatures in the 40s F.
Anyone wanna give it a shot and report back?
-Jon
BBlessing (12-22-2009)
Old 12-22-2009, 02:48 AM   #2
BBlessing
61k happy miles
BBlessing's Avatar
Default Re: NAFTA NCV3 rear axle fluid, MPG impact, going multi-weight synthetic
Attachment 19753
Here's the spec sheet: Attachment 19754
-Jon
jon, you never fail to amaze me. one third the price! wow! if you want to wait till it is warmer, i will buy the oil and we can change our axle grease and see what kind of changes in mileage we each get.
bb
BBlessing is offline   Reply With Quote
Old 12-22-2009, 03:01 AM   #3
jdcaples
jdcaples's Avatar
I'll buy the oil, dude. Just loan me a few dozen square feet on your concrete drive way for a few minutes to do the deed and we'll call it even. :)
-Jon
Old 12-22-2009, 05:28 AM   #4
cedarsanctum
re: Member
cedarsanctum's Avatar
I dunno, draining that much gear oil onto someone's driveway doesn't seem like such a good deal to me. ;-)
Old 12-22-2009, 05:36 AM   #5
jdcaples
jdcaples's Avatar
I have a fluid evac system to remove the lion's share of differential fluid w/o a spill.
For the fill, a drain pan on the ground and some cat litter in case I overwhelm the funnel during filling, should result in minimal environmental impact.
I'm not taking my cover plate off. It's not necessary.
-Jon
Old 12-22-2009, 07:49 PM   #6
sikwan
06 T1N Can
sikwan's Avatar
Do you NCV3 guys have the drain plug?
Old 12-22-2009, 08:32 PM   #7
jdcaples
jdcaples's Avatar
Yeah.
The back plate has the same pry-out plug as your T1N and a threaded drain plug/bolt that uses a 14mm hex driver bit to turn.
I was just going to use a fluid evac system similar to this to pull out most of the fluid through the fill hole, then open the hex bolt to drain the rest without making a huge oil spill.
Then I was going to put the bolt back in and fill through the plug.
-Jon
Old 12-23-2009, 03:26 PM   #8
BBlessing
61k happy miles
BBlessing's Avatar
-Jon
you got it!
bb
Old 07-15-2010, 05:30 PM   #9
glas1700
glas1700's Avatar
-Jon
I've been searching for Mobil Delvac 75W90 recently. The only thing I can find is large quantities (gallon bottles, four per case for $130) from a local Mobil oil distributor, so when I found this link I thought it was the answer until I discovered that the gear oil on the listed website (hrpworld.com) is Mobil 1, not Mobil Delvac. Mobil 1 gear oil is designed for limited slip differentials and doesn't meet the MB 235.8 spec, so consider this before you buy it.
Byron
