Gabe Athouse
Is there any difference between rear axles though the years of t1n? specifically 3500? Not sure if early ones had ABS
I believe that all NAS aka NFTA Sprinters have ABS. ESP was an option until 2004. After that ESP was provided on all NAS models.Is there any difference between rear axles though the years of t1n? specifically 3500? Not sure if early ones had ABS
Also there was more than one axle ratio.All 3500 axles are physically interchangeable as far as I know. There may be differences in the springs depending on body length. All have the same wheel speed sensors.
There may be 2 different caliper MFGs, but they use the same attachments.
Hence the physically interchangeable statement. They will all bolt on, but the modules must match the configuration. Gabe knows this though, from a previous thread. I probably should have included that caveat for other readers.Also there was more than one axle ratio.
Gary
