Old 07-10-2019, 04:19 PM   #1
indigoE
Default Bolting shelves to the interior
2003 T1N Passenger Van
Planning to attach some shelving to the interior of the van, and hope to leave the upholstered panels in place. Is there a schematic which reveals where the steel frame members are located, so I'll know where to drill. (perhaps a carpenter's stud-finder will work?)
I doubt sheet-metal screws would be adequate, can anyone recommend a threaded insert which is best for this application,?
Thanks for any advice.
indigoE is offline   Reply With Quote
Old 07-10-2019, 04:57 PM   #2
Default Re: Bolting shelves to the interior
rivnuts, do a forum or google search.
Its possible a stud finder will work, they do use them on steel studs.
indigoE (07-10-2019)
Old 07-10-2019, 09:48 PM   #3
Find someone with a T1N cargo van without panels ... measure it.
The bodies didn't change from 2001 thru 2006.
--dick (whose 118" passenger van has the lower set exposed)
indigoE (07-11-2019)
Old 07-10-2019, 10:20 PM   #4
Matt Foley
Matt Foley's Avatar
A neodymium magnet might work as a stud finder for that application...
I prefer Plus Nuts and I think they may work better if you're trying to apply them thru the wallboard. Rivnuts have a very shallow "bite collar" (for lack of a better term).
Matt Foley is offline   Reply With Quote
The Following User Says Thank You to Matt Foley For This Useful Post:
Old 07-10-2019, 10:35 PM   #5
Rivnuts should not be applied so that they are clamping the wall panel to the sheetmetal. You will need to drill a larger hole in the wall panel, and a smaller hole in the metal for the rivnut. The large hole needs to accommodate the rivnut tool you choose.
