white whale
Decide at the last minute to see if anything is harvestable before tossing. My convex had gone a while back and the big one had some chips along the edge.
If you want to remove yours....
push in bottom all the way in
flatblade or pry tool to push up, hand pull the rest of the way.
Turns out the reverse is also a mirror, Have not figured out show to separate yet. There is a hole
in the plastic frame that shows the mirror surface.
I doubt a glass shop would cut a shape like this, cheaply.
Will post again if I get the reverse side out, will be a pristine mirror at least.
Assume this was done to be cost effective with the supplier and install - universal fir for either side.
Ok, win for this part.
