Old 03-09-2019, 09:02 PM   #1
itsasprinter
Default Just purchased 05 with black death
Hey!
Long story short this was my buddies 05 140 high top i did most of the maintenance for him in trade i got to use it, I'm remodeling my home so it was a life saver. he decided to sell to me this week it has 130k on the clock he got it at 119k from his brother. it only has some surface rust, zero dents and a slightly leaky windshield. It had a slight tick from time to time, I always thought it was a sticky injector well i was half right. i just learned about the black death. Wish me luck parts are on order!!
itsasprinter is offline   Reply With Quote
Old 03-09-2019, 10:57 PM   #2
HelloPitty
HelloPitty's Avatar
Default Re: Just purchased 05 with black death
Not too bad, I've seen worse.
2004 T1N 2500 158" High Roof
HelloPitty is offline   Reply With Quote
Old 03-10-2019, 01:57 AM   #3
itsasprinter
That's what i was thinking. Any ideas if i should replace all 5 or just do the one?
Old 03-10-2019, 03:13 AM   #4
tinman
If there's just one leaking, I'd leave the others alone.
Edit:
Dennis disagrees. He's way smarter than I am. Ignore me. Listen to him.
2006 LT FreeSpirit 210B. DAD
tinman is offline   Reply With Quote
The Following 2 Users Say Thank You to tinman For This Useful Post:
itsasprinter (03-10-2019), Nautamaran (03-10-2019)
Old 03-10-2019, 06:43 AM   #5
Nautamaran
2004 140 SHC U.S. T1N
Nautamaran's Avatar
I’ve now done two seals in 18 months, so go ahead and buy a couple of bolts and seals for future leaks.
I pull the cover and check for coking at oil changes while the sump drains.
-dave
Old 03-10-2019, 07:46 AM   #6
PortlandSprinterConnection
front yard = sprinters
PortlandSprinterConnection's Avatar
I just did a black death fix on #1 for a friend. He now has it in #4.
Maybe this is a naive thought, but my thinking is that all the injectors have been subject to close to the same parameters over their lifespan, if one seal has failed, aren't the chances of the others failing under those same parameters fairly high?
owned multiple t1ns, currently driving
sprinter tool library available for Portland area forum members, pm me
118, 2006 tall roof, 204k.
PortlandSprinterConnection is offline   Reply With Quote
The Following 2 Users Say Thank You to PortlandSprinterConnection For This Useful Post:
MikeP (03-10-2019), patineto (03-10-2019)
Old 03-10-2019, 08:27 AM   #7
lindenengineering
They should all be pulled out and resealed -THEN--The engine should be checked for localized overheating which causes premature copper injector seal washer failure.
Remember poor cooling system maintenance is what kills this engine and it often goes overlooked.
The Following 3 Users Say Thank You to lindenengineering For This Useful Post:
HelloPitty (03-10-2019), MikeP (03-10-2019), Patrick of M (03-10-2019)
Old 03-10-2019, 04:15 PM   #8
Failure of number 1 seal is often caused by corrosion, as water most easily gets down into the #1 injector well. For a DIY on a non critical usage vehicle; doing just the leaking seal(s) may be a good approach. For a business/mission critical vehicle, doing all the seals proactively may be the correct choice.
Baselining the cooling system is very important with unknown history.
Old 03-10-2019, 04:57 PM   #9
itsasprinter
I have been soaking the bolts in Kroil for the last two days. i just started it up to move it and sure as **** #1 and #2 are in need of replacement. #1 has bubbles of kroil #2 is spraying diesel in the air. Thermostat was replaced 2 years ago, system flushed. This is only a toy i put 500 miles on it last year total. i think the short trips to HD and Menards are going to put a toll on it. Both stores are less than 4 miles from my house. i may have to take it on the express way more often to get it nice and hot.
Old 03-10-2019, 05:01 PM   #10
Don't neglect the viscous fan clutch.
itsasprinter (03-10-2019), MikeP (03-10-2019)
