Old 05-22-2018, 12:48 AM   #1
bcman
bcman's Avatar
Default Power Distribution Block setup
The Power Distribution block on the vehicle battery originally looked like this on my van:
All fuses were bolted down underneath the cable lugs and the top bracket. This meant that if one fuse blew, I had to unscrew all 6 top nuts to remove and replace it.
I decided to re-assemble it like so:
This makes it a lot more user-friendly, and I can't see any downside. Can you?
(side note, I blew the leftmost fuse after almost welding a wrench to the frame trying to remove my alternator. They're not joking when they say to disconnect the negative battery cable first!)
bcman is offline   Reply With Quote
The Following User Says Thank You to bcman For This Useful Post:
Thanasis (05-22-2018)
Old 10-20-2018, 03:59 AM   #2
TimPotter
04 T1N 275,000 miles.
Default Re: Power Distribution Block setup
I have done a similar doofus move and blown a fuse. I can't find any replacements. WHAT ARE THESE FUSES CALLED and where can i find some?
TimPotter is offline   Reply With Quote
Old 10-20-2018, 04:13 AM   #3
Nautamaran
2004 140 SHC U.S. T1N
Nautamaran's Avatar
They’re called “MIDI fuses”
https://sprinter-source.com/forum/at...9&d=1284820700
Appear reasonable at Freightliner / Dodge / MB dealers?
Europarts jist calls them “bolt fuses”.
https://europarts-sd.com/fuse-100amp2002-2009-2.asp
-dave
Old 10-20-2018, 11:40 AM   #4
I've thought that design was pretty stupid too. Because it needs to be accessed so infrequently I didn't do anything with it. The only downside I can see is possibly stressing the fuse tabs. Other than that it makes sense.
Added: You might inspect the alternator lug for corrosion. I think I see some residue. I believe that the OEM solder flux wasn't the best choice. Or maybe it's just dirt on the shrink tube?
... (side note, I blew the leftmost fuse after almost welding a wrench to the frame trying to remove my alternator. They're not joking when they say to disconnect the negative battery cable first!)
Yep. Fortunately the NAS aka NAFTA T1N's have that fuse block. With many vehicles there is no fusing. They just upsize the cables. Without the fuse it could have been more of an issue.
I did it with the FB #1 removal.
Some fuse and relay info.
The High Amp Compact Fuses off the Battery are not easy to find.
https://sprinter-source.com/forum/sh...112#post101112
Fuse Block #2 Fuse Map 2004
https://sprinter-source.com/forum/sh...ad.php?t=24683
Old 10-20-2018, 01:57 PM   #5
pfflyer
pfflyer's Avatar
I bought some spares for the NCV3 from a Freightliner dealer. This was 4 years ago but the prices were in the $1-3 range. I think Dick has posted a parts break down for the T1N in a post. That same post also has the NVC3 part #as as well. ANL type fuses at part stores are close. I had to enlarge a hole with a needle file to get it to fit over the post. It was flimsy and surprisingly more expensive than OEM from FL dealer.
battery, fuse, fuse block, power distribution center
