Old 05-21-2018, 12:07 AM   #1
BGarrett
Default Engine swap advice
I picked up a low mieage engine and transmission for my '04 t1n, and i'm planning on swapping them out n the next month or so. I'd like fo be sure i do everything right, and dont overlook anything while I've got it out. I know about wiring harness issues, but is there anything else that I should really look at while I'm in there? Any advice would be greatly appreciated.
2004 NAFTA Freightliner passenger van
BMJ (Big Mamma Jamma)
270,000 miles, family hauler for wife and kids
BGarrett is offline   Reply With Quote
Old 05-21-2018, 03:04 AM   #2
RileyC
2002 140 shc, 2005 158 sh
Default Re: Engine swap advice
Make sure that the replacement engine has the updated flywheel. The ones on the 02,03 and I think early 04ís came with a flywheel that would develop cracks. The updated flywheel solved the issue. If the new engine and transmission are attached, you can check which one it has through the inspection window on the bottom of the bell housing.
RileyC is offline   Reply With Quote
The Following User Says Thank You to RileyC For This Useful Post:
BGarrett (05-21-2018)
Old 05-21-2018, 05:17 AM   #3
How low is low mileage? If its nearing 100K miles or more, a water pump, serp belt, and related service may be called for. Check the bolts on the back of the HP pump, and put loctite on them if desired. If the replacement engine is from an 04, replacing the pressure relief valve on the bottom of the HP pump (if original) will prevent the annoying (but harmless) fuel line buzzing.
Check and replace any suspect hoses, clean EGR, etc.
Check harmonic balancer for separation, replace if needed.
Old 05-21-2018, 11:55 AM   #4
BGarrett
35k on the low miles engine, so serp belt and water pump might not be needed yet. Iíll definitely look at flywheel, inj pump bolts, and harmonic balancer.
