Old 04-04-2018, 02:26 PM   #1
72chevy4x4
Default alignment off after tire installation
had the two rear tires replaced at Costco yesterday and I could tell something was off right away. Tried playing with the tire pressure in all four tires but something is way off now. The steering feels like it 'floats' or unresponsive.
I checked the front shocks and sway bar but do not see any visual damage. It now feels like there is no sway bar. When going into a corner (Texas hill country) the front end dives into the corner instead of being tight like it was. I had installed SuperSpring helpers on each corner a year ago and it made the van much easier to drive through the hills.
Any clues what I should be looking for that may have caused the damage?
72chevy4x4 is online now   Reply With Quote
Old 04-04-2018, 02:33 PM   #2
Wrinkledpants
Default Re: alignment off after tire installation
Did you change tire brands?
2017 144WB 4x4
Wrinkledpants is offline   Reply With Quote
Old 04-04-2018, 03:37 PM   #3
hmbltn
Guest
Posts: n/a
The only "damage" I can see here is not replacing all four tires at the same time... and presumably not rotating them on a regular basis (that would eliminate this notion of "rear tires" - they should have all been rear tires at one point or another). I would immediately drive down to Costco and replace the front tires as well and then take it to a real tire shop to have the wheels properly balanced and aligned. You're just going to be chasing your tail from here on out.
The Following 2 Users Say Thank You to For This Useful Post:
eralimited57 (04-06-2018), sailquik (04-04-2018)
Old 04-04-2018, 06:52 PM   #4
Ace in the hole
Another thing to look at would be load rating of what ever tires you bought. There are lots of veriables that all could play into the handling change.
Ace in the hole is offline   Reply With Quote
Old 04-04-2018, 07:04 PM   #5
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
It could be your ABS/ASR system kicking in, thinking you are skidding because front and rear wheel speeds are not matching.
Try swapping wheels front to rear, correcting pressures, then going for a drive. If this cures it then the answer will be as above, namely you have to replace all four tyres at the same time.
36,000 miles from New
Old 04-04-2018, 09:10 PM   #6
Dannyboyski
You would know about this, ive had it kick in when I mistakenly put on a steering wheel upside down after fitting cruise control, and its not something you would miss. plus the ABS light would flash.
To the OP you realise there is no wheel alignment on the rear wheels.... only the fronts and even then it is limited to toe in toe out adjustment.
Dannyboyski is offline   Reply With Quote
Old 04-04-2018, 09:56 PM   #7
showkey
Just a note camber on the front is also adjustable...........but likely has nothing to do with the OP issues.
2008 3500 chassis Class C built in 2010
Pulling 6x12 enclosed trailer
showkey is offline   Reply With Quote
Old 04-05-2018, 04:27 PM   #8
Absalom
Why would replacing the rear tires affect the front steering and body roll? Changing tires has no effect on alignment, unless a poor alignment caused uneven tire wear and then replacing those worn tires with new tires caused the pre-existing alignment issues to become more obvious again.
... Was the van dropped off the lift during tire change?
Are the tires out of balance? (Vibrations?) If not, then going to a "real tire shop" (whatever this means - Costco sells tons of tires) will have no effect, unless they also do alignments and the alignment is indeed off.
My money is on incorrect load ratings, but even this wouldn't explain why the front handling changed.
2012 170 with a ton of miles
Absalom is offline   Reply With Quote
Old 04-05-2018, 04:34 PM   #9
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Is it possible your rear axle has come loose at the spring U bolts and is floating freely on one or both sides?
Do you still have a 2008 NCV3 as I can't find mention of any other Sprinter?
Keith.
PS Or it may even be possible that '72chevy4x4' has already cured his problem as he hasn't posted since his OP.
The Following 2 Users Say Thank You to Cheyenne For This Useful Post:
4wheeldog (04-05-2018), sailquik (04-06-2018)
Old 04-05-2018, 05:12 PM   #10
Ciprian
Spark Plugs not allowed!
Ciprian's Avatar
I had the same thing happen to me. After searching online for an answer, some tires need a few hundreds of miles to break in.
Sent from my LG-H918 using Tapatalk
Ciprian
2015 Mercedes-Benz Sprinter, OM651, 40k miles.
2004 Freightliner Sprinter, OM647, 780k miles.
Ciprian is offline   Reply With Quote
The Following 2 Users Say Thank You to Ciprian For This Useful Post:
Aqua Puttana (04-05-2018), sailquik (04-06-2018)
