1. Where it bends over intake manifold, there should be a rubber grommet to protect it. Secure this in place.
2. The injector harness' bare wires lay directly against bare metal on the top of the engine near the injectors afaik. Should be preemptively protected.
3. Behind the fuel filter, the filter mount has a sharp flat piece sticking out towards the driver, which cuts the harness. Zip tie rubber over it.
4. Wires near the heat shield can get cut or burnt, should be secured in place with the little push in wire holders and zip ties.
5. Behind each headlight is a ground attached to the metal body, it gets oily and dirty here, both sides of the the ring connector and bare metal under the ring connector should be sanded till shiny.
6. Battery to chassis ground, the big bolt on the firewall, no clean = no start
7. 13 pin connector on transmission, the o ring can leak, oil wicks up the wires into the TCM
8. Engine to chassis ground frays/corrodes with time
9. Brake light bulbs - The contacts that touch the bulbs were very dirty, arced and corroded, causing my bulbs to burn out, causing an error code.
10. Very important ground under drivers seat. Gets dusty and dirty in here, mine looked ok but wasn't shiny. Good idea to clean it anyway imo.
