Believe this is the replacement for the original bathroom skylight but need to verify. Lots of consolidation (original said Seitz, which then became Heki, then part of Dometic?).
https://www.campervan-hq.com/collections/rv-skylights/products/dometic-heki-mini-plus-rv-rooflight
My original Westy only had an insect screen, while this one has both an insect screen and a blind.
Don't know if this color is the same as original.
While several Westy owners have switched to a Fantastic Fan with European base, some Westy owners may like the original (originalism?).
The Fantastic Fan European base version requires (a) screwholes through the fiberglass top and (b) super careful placement of the internal woodframe to match screwholes or a thicker internal woodframe.
The original bathroom skylight is held by clamping pressure. The outside and inside frames are held together by screws within the frames--the screws do not go through the fiberglass top.
