Old 02-27-2017, 12:19 AM   #1
pointsunknown
Default Espar (Eberspacher) D2 "No Signal" After running for hours
Hi All -
I am having a problem I can't seem to fix on my espar D2 heater with easystart timer. The heater starts up and runs without a hitch. Then after about 5-6 hours of run time it turns itself off with the error "No Signal" displayed on the controller. I can turn the controller on and off and it maintains 'no signal'. But if I pull the fuse on the controller and then restart it it immediately starts up and will run again for 5-6 hours without a problem.
In previous winters, I was getting random errors when it was really cold and the heater was running on turbo mode for long periods of the time. It would kick off with error codes relating to fuel. I thought this might be in relation to my fuel intake routing or altitude so I changed the routing and installed the high altitude sensor into the mix (since the errors only happened when it was really cold outside and I was above 6,000 feet).
Since this fix I haven't gotten any more recorded errors, but I have repeatedly gotten the "No Signal" error. And it really is like clockwork after 5 or 6 hours of usage that it shuts itself down. Every night around 3 or 4 am when we are camping it turns off. I wake up with cold toes, reset the van power (essentially hard restarting the heater) and it turns right back on again and runs just fine till morning.
I've included a couple pictures of the wiring harnesses, for reference.
Thoughts?
pointsunknown is offline   Reply With Quote
Old 02-27-2017, 01:14 AM   #2
sprint2freedom
2008 NCV3 170ext
Default Re: Espar (Eberspacher) D2 "No Signal" After running for hours
Have you played around with the diagnostics?
http://www.eberspaecher.com/en/downl...54_EN_0913.pdf
The "Workshop menu" is described on pages 19-22 for EasyStart Timer / Remote+, and pages 22-23 for EasyStart Select.
Old 02-27-2017, 01:18 AM   #3
sprint2freedom
2008 NCV3 170ext
Fault codes are listed on this site:
http://www.letonkinoisvarnish.uk/Fault_codes.html
Alternate reference:
https://www.pfjones.co.uk/advice-cen...ult-codes.html
https://www.pfjones.co.uk/advice-cen...ing-guide.html
Old 02-27-2017, 01:23 AM   #4
sprint2freedom
2008 NCV3 170ext
Related thread:
https://sprinter-source.com/forum/sh...ad.php?t=44592
I was getting NO SIGNAL Codes as well somewhat often and after talking with Espar Canada, realized I had two "extra" wires connected in between the D2 harness and controller. I clipped them and no codes since.
Maybe re-check your wiring?
Edit: I'm looking at the schematic I drew up for my install and I specifically noted that the yellow wire and whrd wire from the 16-pin connector were left unconnected. It looks to be connected at both sides in your photos. I have the EasyStart Select, but the altitude sensor has 3 wires in (rd/bn/buwh) and 3 wires out (rd/bn/buwh), the EasyStart controller has 3 wires in (rd/bn/buwh), and there are three wires (gyrd/bnwh/gy) going to the external temp sensor.
The Following User Says Thank You to sprint2freedom For This Useful Post:
pointsunknown (02-27-2017)
Old 02-27-2017, 02:59 AM   #5
pointsunknown
Great! Thanks for the quick replies folks. Based on what I am reading it sounds like the yellow wire I have connected is in error. I will cut it and see if that solves the problem, then report back.
I had been reviewing the fault codes, but the 'no signal' error was actually not throwing any fault codes on the diagnostic screen.
Thanks again!
Old 02-27-2017, 05:11 AM   #6
highsierrabear
Maybe check your Time out settings? Just something else to investigate. I wrote about it a bit on my blog in the Espar installation. Your Easy Start timer settings may be different.
2014 170WB DIY conversion. Build started July 2016- finish? LOL.
Outdoor and Van blog- http://radvanadventures.com
Instagram- radvanadventures (vanlife, mountain life, bikes, surf, outdoor porn, cute dog)
highsierrabear is offline   Reply With Quote
Old 07-21-2017, 08:51 AM   #7
Any resolution? Mine started doing this randomly, and now, after pulling the fuse the controller won't recognize the heater. Applying 12v to the switch on signal turns the espar fan on. So the ECU is working, at least partially.
Old 07-21-2017, 06:30 PM   #8
sprint2freedom
2008 NCV3 170ext
Cut.. the yellow.. wire!
Based on the blog entry here, that seems like it may have been resolved the issue, but OP ought to confirm.
Note: I had the yellow wire connected through the high altitude sensor initially, this appears to be incorrect. The heater was working, but I was getting occasional ‘no signal’ errors. Will report back once this new wiring has been tested out more significantly. However, per the wiring diagram to the right, DO NOT CONNECT THE YELLOW WIRE.
Old 07-22-2017, 04:09 AM   #9
I never had the yellow wire connected, so that's a no go for me.
After a bit of testing and some research, I believe my D2 has a faulty ECU. I can hear the ECU come out of sleep mode (relay clicks) when I power up the Easystart timer, but it doesn't communicate. The second heater comm line does the same thing.
I will connect my D5 heater up just to make sure the easystart is not faulty. After some reading I have found that some heaters will overheat the control unit, but not throw a fault code. Ambient temp never seemed to have any effect on the no signal errors in my case, so I may have had a faulty ECU from the start, and it just finally bit the dust.
Just to make sure, I am going to modify the ducting to reduce any flow restriction on the heating air outlet.
A new ECU is around 250$ I think. Of course getting one in Australia would be challenging, as alll Espar stuff is through Dometic, and they are basically crap for support.
Old 07-23-2017, 09:11 AM   #10
I think I fixed it. Long story short, the one wire bus espar uses for digital communication is sensitive to high resistance connections. The main plug for the easy start timer was the culprit. I will be replacing it in the near future.
Fyi, the EST WILL REPORT no signal any time the primary heater can't be found, even if the secondary heater is working fine. Go figure...
Jimoc (10-02-2017)
