Old 10-06-2016, 01:25 AM   #1
FINNDIAN
Default 05 om647 in 03 sprinter?
I have a complete 2005 donor vehicle to fix my 2003 with engine issues. I had hoped to do a complete motor and trans installation, plug and play but now understand there are differences.
If this is the case. Could I transfer the 05 ecm or if that isn't feasible, bolt the om612 fuel system etc on the om647 block?
sent from my wicked android thingy.
FINNDIAN is offline   Reply With Quote
Old 10-06-2016, 02:51 AM   #2
Default Re: 05 om647 in 03 sprinter?
Similar to this, only maybe worse in that the OM647 block isn't set up for a mechanical low pressure fuel pump.
http://www.sprinter-source.com/forum...ad.php?t=50784
Others can probably supply more real world information.
Old 10-08-2016, 03:54 AM   #3
FINNDIAN
Default
Then possibly I could put all the bolt ons from the 612 on the 647 block including injectors and if the block won't accept the low pressure pump I could use an in line lift pump?
Would be nice if I could just use the 647 as is with harness and computer but assume I would have a problem with the computer jiving with the rest of my van
Old 10-08-2016, 01:09 PM   #4
Yes. The OM647 and OM612 computer controllers (ECM aka ECU) are way too different to work on a different model range T1N.
Old 10-08-2016, 01:54 PM   #5
lindenengineering
Rule of thumb
Everything above the block is different including the FI equipment .
Old 10-10-2016, 03:58 AM   #6
FINNDIAN
Default
So you're saying the 647 head couldn't be used
Old 10-10-2016, 05:12 AM   #7
lindenengineering
No
Simply because the HP injection pump aperture in the head is different the older head and some minor chain guide differences. AND the exhaust valves are sized differently
Old 10-10-2016, 09:49 PM   #8
FINNDIAN
Default
So high pressure pump won't transfer either.
I Assume I can't use the 647 pump and 647 injectors with the 612 computer?
If I have to take the head off I may as well just rebuild the 612 and drive the newer van.
Old 10-14-2016, 12:47 AM   #9
FINNDIAN
Default
According to this info the 647 injectors work with the 612 computer and the hp pump will transfer. Strange it doesn't work in the opposite direction.
Some info. Thanks goes to azzm3.
Yes the injector connectors are the same and are triggered by OM647 ECU with no issues.
Complete fuel rail from OM647 is also transferred over. You change the front plate where the low pressure pump mounts with one from OM647. Also OM647 high pressure pump is used and it does mount up like its suppose to. In simple terms you strip OM612 to block and head leaving injectors in and dress it up with OM647 components wiring,turbo,rail,pump etc. Everything functions like it should with no warning lights and limp modes (I use DRB3 for all diag on T1n). I have driven swaps like these cross country with no issues.
This is a reply to Aqua Puttana
The Following User Says Thank You to FINNDIAN For This Useful Post:
Aqua Puttana (02-27-2017)
Old 10-14-2016, 05:36 AM   #10
I interpret your question a couple posts above for using a OM647 head on a OM612 engine.
I interpret what Dennis said was the head won't work.
I didn't interpret that answer as the other stuff not working. If the high pressure pump and fuel rail transfers from the OM647 to the OM612 then it pretty much must go the other way too. Maybe not. See below.
Try to be specific with the questions. It may get a bit clearer information.
Added:
Do your research before going too far.
Some input from Doktor A.
It appears you are asking whether a 647 long block (cylinder head included) can be used.
The complication you have is mounting and driving the mechanical feed pump and the 612 high pump.
The 647 intake cam lacks the drive extension for the 612 feed pump and the 647 upper chain ramp plate lacks the opening and threaded mounting holes for the feed pump.
The 647 cylinder heads' bolt pattern for the high pump will not allow mounting of your 612 high pump.
Doktor A
And comments by Dennis Lindenengineering that the lower end is ok.
Rule of thumb
No
