Old 07-10-2016, 11:40 PM   #1
Eugene Rider
2016 Unity TB
Default Lithium battery install
I have been asked to supply pictures and progress about my lithium battery install.
I picked up my "install" kit last Thursday from AM Solar.
I only have two of the batteries, the other two are coming.
I'm installing 4 Victron 12.8v/90ah batteries, Victron 3000 watt inverter with color monitor and a Victron BlueSolar charge controller. (according to AM Solar, more amps will get threw, 10-30% more).
Lots of relays and wiring.
I hope to install all 4 batteries and lynx distributor 1000 in the compartment behind the coach door, the now battery compartment wii hope in inverter along with wiring a relays.
Sleeping has been marred with waking up, thinking about all the work ahead.
I'm also installing a National 270 amp alternator as I didn't get a generator with my Unity TB.
Eugene Rider is offline   Reply With Quote
The Following 3 Users Say Thank You to Eugene Rider For This Useful Post:
irontent (07-10-2016), leei (07-11-2016), Mike Thomas (07-11-2016)
Old 07-11-2016, 12:24 AM   #2
alichty
2014 LTV Unity TB
alichty's Avatar
Default Re: Lithium battery install
This looks serious <pulling up chair to watch>.......
Alan Lichty
2014 Unity TB
alichty is offline   Reply With Quote
The Following 2 Users Say Thank You to alichty For This Useful Post:
Custommm (07-17-2016), Eugene Rider (07-11-2016)
Old 07-11-2016, 02:15 PM   #3
Peter Tourin
2012 LTV Unity MB
Peter Tourin's Avatar
Me too - this looks like a really interesting project. You sure went for the nice stuff <g>...
Peter Tourin
2012 Leisure Travel Unity MB
Old 07-11-2016, 03:06 PM   #4
cooltravelers
Peter,
What will be your total battery weight for the four? Compare to your original weight for 2 lead acids. Make lots of photos.
2017 Unity MB
cooltravelers is offline   Reply With Quote
Old 07-11-2016, 04:28 PM   #5
Peter Tourin
2012 LTV Unity MB
It's not my project, I'm just lurking and gabbing <g>... But the Victron batteries aren't particularly light,it looks like they're around 33 lbs each. I think my 2 stock batteries were 47 lbs each. But there's way more capacity there. Stock batteries would be around 180 aH total, and if you use the 50% rule to keep them from degrading quickly, you have 90 aH usable capacity. Four 90 aH lith batteries is 360 aH total, but you could use 80% of that, so you have 325 aH of usable capacity. Plus you can charge/discharge them at a high rate. If I understand the original post, he's adding an extra 270 amp alternator - if that's true, he can pull the battery bank way down and then recharge by driving around for somewhat more than an hour. That's a lot of gain.
Peter Tourin
The Following User Says Thank You to Peter Tourin For This Useful Post:
Old 07-11-2016, 10:30 PM   #6
Eugene Rider
2016 Unity TB
Very close 31 pounds
Old 07-12-2016, 02:05 PM   #7
jackfish
325 AH of usable capacity in Fullriver AGM batteries would weigh 426 lbs. 426 minus 124 equals 302 pounds saved. Now what is the typical cost of the lithiums? Up to $1800 for the Fullrivers, and then one would have to find the room for them (I guess Gamma1966 did).
The Following User Says Thank You to jackfish For This Useful Post:
Chip D (07-12-2016)
Old 07-12-2016, 05:12 PM   #8
Boxster1971
2012 Sprinter 3500 Ext
Boxster1971's Avatar
Eugene - that looks like a great project. I join those waiting to hear more on how it goes together. How do you plan to deal with freezing temps impacting charging ability?
-- Mike
2012 Sprinter 3500 EXT Airstream Interstate Conversion
Old 07-12-2016, 06:22 PM   #9
Eugene Rider
2016 Unity TB
These are $980 per battery, so $3940. I'm spending the money that I saved on not having a generator. With 3 more solar panels for a total of 5, the 270 amp alternator and all the goodies, I'm going to be pushing $12k. But, it's a hobby so it priceless.
The Following User Says Thank You to Eugene Rider For This Useful Post:
jackfish (07-12-2016)
Old 07-12-2016, 06:30 PM   #10
Eugene Rider
2016 Unity TB
