Old 06-10-2016, 04:08 AM   #1
floydturbo
Folsom, CA 2015 w170ex i4
floydturbo's Avatar
Default diy rear door spare tire carrier
I placed my air conditioner compressor and condenser under my van and need to relocate the spare tire. I saw the eurocamper one online for $299, but is out of stock as of now. It looks like it only works for steel wheels as the wheel is mounted with the inside facing out. I have alloy wheels and cannot mount them that way.
I bought a spare tire mount for a Land Rover Discovery 1 off ebay, used. I cut off the mounting bolts and bought 3 studs that were 12mmx1.50 and 2.50" long. I welded these onto the Land Rover mount and then primed and painted it.
I had to remove the rubber bumper stop from the door and sealed the hole.
I used 40 series 8020 to make the vertical pieces for the mount. I tried to center the middle of the spare tire about 1" above the Sprinter logo on the rear door and in the center of the door from left/right.
2015 170ext i4/7sp
floydturbo is offline   Reply With Quote
The Following 10 Users Say Thank You to floydturbo For This Useful Post:
Aqua Puttana (06-15-2016), ddunaway (12-31-2018), dynaco1 (06-18-2016), GlennR (12-28-2018), Hartusi (09-15-2018), hein (09-22-2018), Mein Sprinter (03-13-2019), MillionMileSprinter (06-13-2016), pdxkid (01-02-2019), Surveillance Van (03-03-2019)
Old 06-10-2016, 02:07 PM   #2
Default Re: diy rear door spare tire carrier
Nice use of materials. Did you use backing plates? My experience indicates that without backing plates you will eventually get cracking in that sheet metal at the mounting points.
Old 06-10-2016, 02:47 PM   #3
floydturbo
floydturbo's Avatar
Did you see cracking in the door sheetmetal?
2015 170ext i4/7sp
Old 06-10-2016, 10:00 PM   #4
Surveillance Van
Surveillance Van's Avatar
Default
Nice work
Thank you
Surveillance Van
Surveillance Van is offline   Reply With Quote
Old 06-13-2016, 02:05 PM   #5
I helped a friend install a door mounted tire carrier on his toyota. It only came with small backing washers. After a trip with some washboard roads he noticed spider cracking around the mounting holes.
In my day job I am an engineer in aerospace, so I deal with fatigue cracking on a regular basis. I can't guarantee your setup will crack, simply because I don't have the details. In practice a 3x3" backing plate is a good design choice. The exception would be if the panel has existing reinforcement within an inch of the mounting holes.
A indication of future problems is if vibration/driving causes the panel to oil-can under the weight.
Matt Foley (03-15-2019), SD26 (04-22-2019)
Old 06-15-2016, 07:25 PM   #6
floydturbo
floydturbo's Avatar
Default no visible vibration
I can watch the rear door spare tire on my rear view camera while on the highway. From the screen, I cannot see any vibration. Time will tell if there are any issues with the door skin, but for now it looks good.
2015 170ext i4/7sp
Old 06-15-2016, 08:59 PM   #7
Stress cracking is definitely something to watch for with that method of mounting. I haven't witnessed it on Sprinters, but have seen it on other vans.
In my experience the Sprinter body metal is quite brittle as compared to body steel on older model vans.
Your installation looks great. Just keep an eye on the mount points as Midwestdrifter suggests.
If backing plates need to be added my preference is a round shape, or square with a decent radius on the corners.
SD26 (04-22-2019)
Old 09-15-2018, 03:13 AM   #8
Hartusi
Default Re: no visible vibration
Have you had any issue with stress cracking over time? Your installation looks like something I would like to imitate. Nice job!
Hartusi is offline   Reply With Quote
Old 09-15-2018, 03:30 AM   #9
floydturbo
floydturbo's Avatar
No issues at all.
2015 170ext i4/7sp
The Following 2 Users Say Thank You to floydturbo For This Useful Post:
hein (09-22-2018), Shiryas (03-16-2019)
Old 12-28-2018, 02:55 AM   #10
floydturbo
floydturbo's Avatar
none
2015 170ext i4/7sp
GlennR (12-28-2018), hein (03-04-2019)
