Old 06-03-2016, 06:40 PM   #1
cwildman
Default tire chains
Hi all, should I get tire chains for my unity? if so what kind (standard tires). Live in NW. charlie
cwildman is offline   Reply With Quote
Old 06-03-2016, 08:03 PM   #2
hayduke
2005/2006 leisure travel
Default Re: tire chains
now that is a riddle.
If you are a wildman,then I would say yes
2005 158wb 2500 Freightliner Leisure Travel Free Spirit
hayduke is offline   Reply With Quote
Old 06-03-2016, 09:14 PM   #3
alichty
2014 LTV Unity TB
alichty's Avatar
If you intend to drive it over any of the Cascade passes during the winter months then you might want to have some on hand. I carry these:
http://www.lacledechain.com/light-tr...rt-super-sport
You can pick up a set at O'Reilly auto parts stores. The correct stock number for our application is #2323 as verified by the Laclede folks. The spray on foam insulation in the Unity wheel wells pushes us into needing the low profile version.
Alan Lichty
Mistral - 2014 Unity TB
alichty is offline   Reply With Quote
The Following User Says Thank You to alichty For This Useful Post:
Eugene Rider (06-04-2016)
Old 06-03-2016, 11:56 PM   #4
JoePhoenix
2016 Unity TB
As I came up over the Snoqualmie Pass yesterday, I thought about all those "chain up" and "chain removal" areas, and said to myself, "No way!" I also tow, so that makes it even harder. But I'm sure if you had to travel in the NW up and over the passes, alichty has the answer. Best of luck!
2016 LTV Unity TB
JoePhoenix is offline   Reply With Quote
The Following User Says Thank You to JoePhoenix For This Useful Post:
E.Wolfe (03-13-2017)
Old 06-08-2016, 05:59 AM   #5
SiennaGuy
Do you have to put chains on all 6 wheels on a dually?
SiennaGuy is offline   Reply With Quote
Old 06-08-2016, 06:02 AM   #6
alichty
2014 LTV Unity TB
alichty's Avatar
Nope - the MB manual says the only wheel to chain is the outside tire in the rear.
Alan Lichty
CJPJ (11-10-2017)
Old 06-08-2016, 06:10 AM   #7
SiennaGuy
I found the answer to my question. Laclede has a section on their site that explains the laws regarding chains for every state except Florida. Florida, apparently, has no chain laws. Here's the link:
http://lacledechain.com/images/State...ire-Chain-Laws
Old 06-08-2016, 07:05 AM   #8
pattonsr
alichty,
I looked at the link you provided for Laclede chains. The chart says for the Unity 215/85R16 tire the model is #2317. You said it was #2323. So I took a tire size of 245/75R16 from the #2323 list and compared the tire sizes. The 215 tire has a diameter of 30.4 inches vs the 245 with a diameter of 30.5 inches. Other dimensions were identical.
Any thoughts?
pattonsr is offline   Reply With Quote
Old 06-08-2016, 02:23 PM   #9
alichty
2014 LTV Unity TB
alichty's Avatar
The model #2323 is the one recommended by one of the engineers at Laclede given the tire size on my Unity - 245/75R16. Where did you come up with the 215/85R16 size?
Alan Lichty
Old 06-08-2016, 09:24 PM   #10
hotfudge
2015.5 Unity TB
Our 2015.5 TB has 215/85R16 tires. The Laclede #2317's are the proper size chains for the 215/85R16. (I have a set) Curious if LTV/Mercedes changed tire size to 245 after 2014 or did you upsize a bit when replacing tires?
hotfudge is online now   Reply With Quote
