T1N Talk General Discussions related to T1N Sprinters. |
anyone know where to find a thicker than oem Head Gasket ?
thanks |
#2 |
Why do you need a thicker head gasket?
Curious have you over-decked it Dennis |
#3 |
machinist says the cylinder head has been shaved before .005 according to stamp on cylinder head. says the head is straight but the burn marks around the cylinder are at least .004 deep and would be too much to deck off (remove) unless a thicker head gasket was used.
engine was recently rebuilt by a big company 4000 miles ago and blew a head gasket. any thoughts ?? |
#4 | |
Be warned.
DAD NAS (N. Amer. Spec) 2004 140 2500 >330,000+ mi. 2006 Freightliner 140 2500HC >183,000+ mi. Arctic Whitewash (Spotted Snow Leopard accents) "My opinion and worth everything you'll never pay for it." assumed. Anyone can hold the helm when the sea is calm. Publilius Syrus "There are only 10 types of people in the world: Those who understand binary, and those who don't." HaWiiLuVeR 16 ounces of unnecessary prevention can be worth a pound of manure. |
The Following User Says Thank You to Aqua Puttana For This Useful Post: | techshooter02 (02-03-2016) |
#5 |
I was reading that thread last night...good information. And the head is still straight no warp. just the indentations around where the cylinders mate up to the head, the machinist called it burn marks. I'm sure they was there after engine rebuild and the resurface of the head the first time but didn't come out all the way. I'm worried they will cause another head failure in 4000 more miles.
what if the new head gasket was coated with the copper coating before installation ???? also what about a good source for a new cylinder head ? anyone know of any. Last edited by techshooter02; 02-03-2016 at 04:08 AM. |
#6 |
Ive never looked for sprinter head gaskets but I imaging this will be a custom part. What I would do:
Call around for machine shops and find one with a water jet or laser cutting machine. Make a tracing of your gasket just in case. Order a sheet of copper in the appropriate thickness. For small stuff I've made gaskets using a hollow punch set, abrasive type hole cutters, and a lot of patience. Dont recommend that though.
2006 Dodge Sprinter 2500, 140" WB, OM647 Engine 2.7L ![]() ![]() ![]() ![]() |
The Following User Says Thank You to misterbond10 For This Useful Post: | techshooter02 (02-03-2016) |
#7 |
There is a thicker head gasket available in Europe. USA doesnt seem to have it. There is an Elring and Mercedes part number for it, if I remember correct. Contact me if you need details.
2006 3500 with 12' Supreme Box Van |
#8 |
another idea: have you thought about stacking two together? Head gasket sandwich...mmmmmmm
The Following User Says Thank You to misterbond10 For This Useful Post: | Thefwafwa (03-19-2016) |
#9 |
more thoughts..
the thicker head gasket I saw on an European Ebay site... I think they ship to USA .. the part numbers are from Elring catalog, they come in different bore diameters. My head was decked 0.0075" and the fellow who built the block convinced me to use the stock gasket as they had seen heads decked more and still use the stock gasket with no apparent problems. But I had the valve seats ground back to the maximum setback distance and the valve stem tops equalized. Make sure you check for cam bind per the previous post.. before progressing any further....as the head might have been previously warped a little. Decking wont solve this. Also check with Memo Parts in Dallas? for kolben-schmidt heads, as they might be better than the Spain heads and maybe even cheaper.
#10 |
Away with the fairies.
Two head gaskets are thicker, so are 3 of them
Current ride Ford Territory reliability, full time 4x4, 6 speed auto, 2.7L V6 Diesel Durotech, 8.5 litres per 100 kilometers. Previous vehicles. 2002 Ford F250 Super Duty (excellent for 13 years from new) 2004 Mercedes T1N 316 (secondhand ex ambulance) 2011 Mercedes Vito 115 (secondhand ex police camera vehicle) 2011 Mercedes NCV3 316 cab chassis 4x4 (secondhand absolute piece of sh!t, I hope it burns in hell) Last edited by Tooth Fairy; 02-09-2016 at 08:17 AM. |
Thread Tools | |
Display Modes | |
