Wasaabi
Sprinter Westfalia #133
My Onan generator has only 55 hours on it. At the moment, it will only run with the rear cover off (which you are not supposed to do for long), or with the air filter cover removed, and the cover on. If I leave the air filter cover on, as I cover get within one inch of closing the access cover completely, the engine starts to idle down and sputters out as soon as the cover is closed. If I leave the air filter cover off, I get a bit of a sound when I approach closing the rear cover, but it stabilizes when closed.
When I bought the Westy a year ago, the generator wasn't running, so the seller had it repaired at an RV place which found nothing wrong but got it going. About 6 months ago when I started it, it was surging with very uneven idle. The next time I tried to start it for "exercise", it would not start.
It has taken until now to get to it. So far I have changed the oil, removed, cleaned, and re-gapped the spark plug (to .020"), tested for spark with a spark plug tester (positive), played with the circuit break up/down. There doesn't seem to be a 5amp fuse in mine (labeled as such near the circuit breaker under the generator access panel). I've also removed the air filter, which looks totally clean, and makes sense considered the nearly nonexistent use. I checked the black tube that comes down on the left for any obvious debris/bugs. Nothing I could see. So I took a turkey baster and tried to use vacuum motion to see if anything would come out. Nothing did (although the vacuum that I achieved was very weak).
When it still wouldn't start, I began playing with things with the rear cover off. What I found is that if I move the little black thingy which rotates and moves a little arm, just to the right of the air filter housing, it will start right up. This black thingy (sorry for the lack of tech terms) just rotates about 90 degrees with no spring tension or resistance. Then it will keep running (so long as the access panel is off or the air cleaner housing is uncovered but with the filter still in when the access panel is closed).
I can push another actuator arm, further to the right, to get more or less throttle. So that seems to work. Next I took the air filter out again and stuck my finger in the larger of the two holes. I could feel a valve/door of some sort in there. I can push this door to various open/closed states, and again there is no resistance or spring tension. Does anyone know if that is supposed to be like this?
I am imagining I have some sort of limited airflow issue, thus with either of the covers off, I get just enough air to make things run. If this points to an obstruction in the black tube, how do I clean that out? I cannot get this tube to pull out. And I am afraid that if I stick anything in there I will cause more damage. Is there any way to remove this whole tube? Is there anything else that could be wrong?
Oh -- one more thing to clarify: It doesn't want to start with both covers off unless I move the black thingy. Once I do while holding the start button (on the generator itself), I get instant start. It reminds me of a manual choke control on old cars. It seems if I hole start down for quite a while, once in a while I can get it to start with both covers off. But every time I fiddle with the black thing, I get instant start.
I am not an engineer or mechanic, but I can follow instructions. I have looked at the Onan manual and tried to research answers, but no success yet. Anyone have any suggestions?
