A2zsprinter
I have a 2006 Dodge Sprinter 3500. The blower stopped working on all 4 settings when in heat or vent mode however it does blow on all 4 settings when the AC compressor is engaged.
I was fortunate to have parts house friend plug up new blower resistor and also new blower motor which did NOT correct the problem. The results were the same.
The blower works on all 4 fan settings when the ac compressor is engaged but does not blow as hard as it should in any of the 4 settings with ac activated. The blower will not work on any of the 4 fan settings for heat or air circulation via blower / fan control switch. Having tried new blower resistor and also new blower motor with same results I suspect heater control module, however refurbish sprinter electronics man from ebay is not sure it is in the climate control panel.
Heater fan control went out for a day then back on for a day then out again.
I went over all fuses several times and have found none blown under seat or below steering column. I would like to eliminate any other likely problem before concluding it is the climate control panel in the dashboard... Please advise.
Your experience/ knowledge is deeply appreciated.
KY Sprinter
KY Sprinter
