Old 04-17-2015, 11:46 PM   #1
pfflyer
pfflyer's Avatar
Default A convertible Sprinter
Not a topless convertible but a van convertible from cargo to camper then back to cargo. This van is first a cargo work van and maybe 20 days a year (1 or 2 nights trips at a time) a camper. I wanted something more than an iron tent but one that could be converted in about an hour. Another requirement is it needed to be able to go back to as close to stock when and if I decide to sell. That means not a lot of holes and alterations. So far I think I have achieved this with only a few exceptions.
First a little bit of history. I bought a 2002 with 367,000 miles back in 2012. Fell in love with the van and then stumbled onto this website. Never thought about using a van for camping but after looking at all the great builds here I got the bug. If I was going to do this I wanted a van with fewer miles that I could go cross country with little worries. That and business picking up I decided to buy a new 2013 crew cargo as my starting point. Alloy wheels added about 40k miles.
pfflyer is online now   Reply With Quote
Old 04-17-2015, 11:50 PM   #2
pfflyer
pfflyer's Avatar
Default Re: A convertible Sprinter
We are not concerned about stealth camping and all of our trips except for Sprinterfest East have been at campsites with shore power. After sound proofing (Dyna-mat) and insulation (reflectix, ridged foam and fiberglass in some locations) my first additions were to be things that I could use for work and camping until we were sure we were going to like camping. To start I added E-track on the walls for a bed platform and also to secure cargo in work mode. Our first trip was basically a bed platform, standard queen size mattress, a folding table, porta-potty, TV, cooler, camp stove, ceramic heater, about 10 storage totes and most important a coffee maker. For power I used an extension cord fished up from an access hole under the van in front of the rear bumper to the rear pillar to a power strip. To wash our hands I used an auquataner over a 5 gallon bucket.
Our first trip was just an overnight trip and we both liked it. So instead of plywood base and a heavy and bulky regular queen mattress from our guest room we tried an air mattress the next trip. That was almost a disaster so it evolved to 4 sections of ply, 3” of foam covered with a vinyl upholstery and a much easier to handle 2” memory foam mattress topper. We are both happy and comfortable with this set-up. Next conversion the only thing I would change is from plywood for the base to ” to make it a little lighter to handle.
To eliminate some of the totes (some were for work/camping like straps and tools) I added a Kobalt SS tool box to stay in full time. Originally I had bought some T-Slots series 10 which is like 80/20 to make a cabinet. This was much quicker. To secure it I cut holes in the bottom where 2 factory tie downs were and used a bolt through the tie down ring and large washers and nuts. The bolt rests on top of internal reinforcements on the floor or edge of the cabinet. Also 2 nutzerts anchored in the wall. If I needed to install the crew bench I would not have to remove this cabinet. To replace the two factory mounts I covered up I installed these. Used for lighter loads. This cabinet holds tools, straps and 1 drawer inventory that I remove and use for toothbrushes and other toiletry items for camping.
I then added this of wire shelving I used for catalogs in the basement for extra storage, counter space and a place for the cooler and eventually my refrigerator. This also stays in full time and is just held down with bungee cords and the plastic molded top of the tool box.
Last picture is the van set up for work.
The Following User Says Thank You to pfflyer For This Useful Post:
Bobnoxious (11-16-2015)
Old 04-17-2015, 11:57 PM   #3
pfflyer
pfflyer's Avatar
Needed something better than washing our hands over a 5 gallon bucket. So I bought these 2 Gladiator cabinets from Home Depot. The bank of drawers is for cloths and dry goods and the other for a sink. The bank of drawers is fastened to the e-track with this custom threaded adapter. I have a couple extra for sale if anyone is interested. The two cabinets are bolted together with aluminum angle from corner to corner for extra strength. While in motion I use a ratchet strap for good measure. Sink top is a piece of corian I picked out of dumpster at a cabinet shop and the faucets are from a bathroom I remodeled. 12volt Shureflow pump is on the shelf and aquataner for fresh water and bucket for waste. This water is basically for clean up and we use a gallon of distilled or drinking water for coffee and bottled water in the fridge to drink. I can get it to what you see here in less than an hour from my work setup.
The Following 3 Users Say Thank You to pfflyer For This Useful Post:
Bobnoxious (11-16-2015), cristici (05-22-2017), gnach (07-05-2015)
Old 04-18-2015, 12:05 AM   #4
pfflyer
pfflyer's Avatar
127ah house battery installed under passenger seat and inverter and battery charger in custom console. I can power inverter from house or starter battery with a battery selector switch. This allows me to charge my house battery with a 3 stage charger while driving. I have a 15amp transfer switch when plugged in.
Old 04-18-2015, 12:14 AM   #5
pfflyer
pfflyer's Avatar
Here is how I hook up to 30amp shore power. 1 15 amp circuit dedicated for heater or portable a/c. I have an auto switch for the other 15 amp circuit to transfer power from invertor. Fished 10 gauge wire from hole already under van to rear pillar to Blue Sea breaker. I used a hatch cover instead of the factory plug to cover the hole and make easier access. I have a 30 amp inlet that I am going to replace this hatch cover with to make it even easier to plug in. I have cable on other side for cable TV or antenna. Same hatch cover and wire run to TV mount.
The Following 9 Users Say Thank You to pfflyer For This Useful Post:
Aqua Puttana (06-23-2015), Bobnoxious (11-16-2015), Cwhite87 (08-01-2019), d_bertko (04-19-2015), gnach (07-05-2015), hein (04-18-2015), HelloPitty (06-10-2016), RoadToad (04-06-2019), surlyoldbill (04-18-2015)
Old 04-18-2015, 12:17 AM   #6
pfflyer
pfflyer's Avatar
I cant begin to thank all the contributors here. With out this forum and all the great ideas I would have never thought about this dual purpose van.
The Following 2 Users Say Thank You to pfflyer For This Useful Post:
Bobnoxious (11-16-2015), Evil Patrick (04-23-2015)
Old 04-18-2015, 12:29 AM   #7
surlyoldbill
surlyoldbill's Avatar
A few years ago I saw camping setup that was a one-piece unit that slid into through the back doors. All cabinets, walls, bunks, water, aux batteries and electronics attached inside the cabinets. Kind of like a camper for a pickup bed, but without a top. It was a pretty slick idea, if you have somewhere to store it when not in use.
Former owner of Surly Mobile:
The Following User Says Thank You to surlyoldbill For This Useful Post:
pfflyer (04-18-2015)
Old 04-18-2015, 12:39 AM   #8
hein
Van Guru
Well done! I see a lot of new great ideas in your build. Thanks for sharing.
A nice touch (imho) would be painting the bed cross members black to go along with your cabinets (-which look awesome, btw).
2010 MB 3500 RV conversion.
hein is online now   Reply With Quote
Old 04-18-2015, 12:44 AM   #9
Aggie
2010 Roadtrek SS Ideal
Interesting photo write up, a very functional dual purpose unit.
Thanks for sharing.
Aggie is offline   Reply With Quote
The Following User Says Thank You to Aggie For This Useful Post:
Old 04-18-2015, 01:18 AM   #10
pfflyer
pfflyer's Avatar
Thanks for the kind words. I wished I had your skills in my build. Painting the cross members is on my list of things to do. Not shown is a headboard that covers the back windows for privacy and a shelf that also needs to be painted or stained. Also on my list is a strip of LED's front and back under the platform to shed some light under there. I tested the front one and it works great and we are going to try it for a night light too.
hein (04-18-2015)
