Old 04-12-2015, 04:17 PM   #1
Kmoderndesign
Default Split intercooler hose?
I have 2 codes for fuel injector open circuit. P0201 and p0204. I also noticed a rushing air sound when pulling out of the driveway. I found the intercooler on the passenger side split. I've only had the van 2 days and the previous owner said it will stall and not restart after driving 10 or 15 minutes. It will restart after it cools down. My question is which of these issues cause the van to shut off and not restart? I have not driven it long enough to experience it myself , I drove it home , it seems to run well except for a lack of power. 2006 244k miles
Kmoderndesign is offline   Reply With Quote
Old 04-12-2015, 06:39 PM   #2
mehr4x4
Default
I'm not near my computer to tell you what those codes are but we lost an intercooler hose on our 04 and it threw a check engine light. After a bit it would but the van into limp mode but never shut down. It's not good to drive very far without the proper boost. Is the actual cooler split or just a hose? I've heard of people using duct tape around a boost hose to buy a little time. We happen to be near a sprinter shop so we were able to fix ours right away. God was with us :cool:
Hth
Eric
Sent from my DROID RAZR HD using Tapatalk
mehr4x4 is offline   Reply With Quote
The Following User Says Thank You to mehr4x4 For This Useful Post:
Kmoderndesign (04-12-2015)
Old 04-12-2015, 06:42 PM   #3
beachbum57
2003 LTV Free Spirit
beachbum57's Avatar
Default Re: Split intercooler hose?
You might try the search function for no start when hot. There are many discussions about this very thing. In fact, there is one currently being discussed regarding "03 stalls while driving, no start".
If I remember correctly, it is probably a fuel injector problem. And you said that you are getting codes for fuel injector.
The split hose is probably causing the loss of power.
Jo
2003 LTV on 2002 Freightliner, OM612, 158 wb.
beachbum57 is offline   Reply With Quote
The Following 2 Users Say Thank You to beachbum57 For This Useful Post:
Kmoderndesign (04-12-2015), surlyoldbill (04-13-2015)
Old 04-12-2015, 07:21 PM   #4
sailquik
sailquik's Avatar
Kmoderndesign,
What sort of diagnostic scanner developed your P201 and P204 codes?
Could be an injector #1 and Injector #4 issue, but with purely generic codes there is no way
to tell if this is correct information and you have a couple of bad injectors, or it could be something
else entirely....as simple as a fuel filter that needs to be changed.
LHM is there to protect your expensive engine from being damaged by being driven when all it's
systems are not functioning optimally.
Find a DAD or DRB-III unit to pull the actual MB specific codes and you will have a much better idea
of what is wrong and what the best remedy is.
The "rushing air" sound would indicate a pressure leak somewhere in the turbo/intake plumbing,
perhaps even a simple turbo resonator failure (this happens often with the OM-647).
If the intercooler is actually split, and your turbo boost pressure (MAP) is escaping out the
crack/split in the intercooler, get a new intercooler that can give you the full 35-37 PSIA boost
pressure.
Then go after the possible injector codes. If it cannot develop sufficient boost due to the leak,
it will set LHM every time you ask for more power than the engine can make without normal
boost/MAP pressure.
Hope this helps,
2019 Sprinter 519/907/VS30 series (3500 DRW) 170"/4325 mm wb Hi Top Short Back
OM-642 3.0 liter V6/7G-Tronic, 7 Speed manually shift-able transmission.
OEM back up camera, LED light package, fog lamps,
Had 2014 516 OM-651 I4/7G-Tronic|2010 NCV3 519/3500/144|2011 & 2012 NCV3 519/3500 170
2006 T1N 3500/158
Old 04-12-2015, 07:38 PM   #5
Kmoderndesign
Great info Rodger. Thanks a bunch. The hose from the turbo to the intercooler has a huge gap. The codes are for faulty injectors I belive. I'll start with fresh filters and intercooler Hosea the. Chase down the injector issue.
Old 04-13-2015, 01:36 AM   #6
surlyoldbill
surlyoldbill's Avatar
Leak off test might identify injector problems, it did for me.
Former owner of Surly Mobile:
