Old 03-10-2014, 03:48 AM   #1
VestaEntrps
Thumbs up 3500 Rear Brake Pads
Nice and easy
VestaEntrps is offline   Reply With Quote
The Following User Says Thank You to VestaEntrps For This Useful Post:
bobojay (03-10-2014)
Old 03-10-2014, 07:59 PM   #2
Murfybed
Default Re: 3500 Rear Brake Pads
If I knew him , I would take out a big life insurance policy. Jack stands are very cheep. Good info on brake job.
Murfybed is offline   Reply With Quote
Old 03-10-2014, 11:54 PM   #3
kendall69
Few things, the top bolt was stripped on the end, second he greased everything except the lower plunger.
Why grease the bolts? If anything you use thread loc. Next no torque wrench - scary.
I was chocking just watching - as he was brushing the asbestos dust with no mask, but then smoking isn't doing his lungs any good any way so what's the difference.
2007 144" Diesel
Old 03-11-2014, 12:31 AM   #4
sailquik
sailquik's Avatar
Beyond killing himself when the entire rear of the Sprinter falls off the floor jack under the Dif pumpkin,
the rotor in the photo is way beyond worn out.
Probably wear out his new pads in a few thousand miles.
Check the undercut on the outer edges of the rotor.....scary!
Maybe this is why some Sprinters get very poor rear brake mileage, and I've consistently gotten great
rear brake mileage.
Never have replaced the brake pads on any Sprinter I've owned.
