Old 02-04-2014, 06:30 PM   #1
Themajickman
Themajickman's Avatar
Default Brutal ride
I just purchased a 2007 Dodge sprinter 2500 passenger van and had it modified with a lift and tiedowns that serves as my handicap vehicle. I ride in the back in my wheelchair and I realized after my first ride that it was totally brutal on my body and kidneys especially. I would like any suggestions on how to soften the ride. It's my understanding that airbag suspension runs about $8000 which is completely out of the question. Also, since my van was "born" as a passenger van rather than a cargo van it already has the softest Springs available so, new Springs would not be helpful. My next area would be maybe tires. Does anybody have any suggestions about different tire sizes, etc. etc.?
The ride is so rough that I would sell the darn thing if I can't fix it
***Paralyzed from the Neck down but Still Enjoy Riding***
***Live Your Life Impeccably***
2007 Dodge Sprinter 144" - Brilliant Silver Metallic - Purchased December 11, 2013 with 58.5 K Miles
Themajickman is offline   Reply With Quote
Old 02-04-2014, 06:45 PM   #2
OrioN
2008 2500 170" EXT
OrioN's Avatar
Default Re: Brutal ride
What are your current tires, and the tire pressures front & rear?
Do you know if the the van had any spring modifications done to stiffen?
Themajickman (02-04-2014)
Old 02-04-2014, 07:55 PM   #3
72chevy4x4
do passenger and cargo van's have different springs?
check the air pressure. Tires make a difference-there is a chance that getting a new set of Michelin's (my choice) would help.
72chevy4x4 is offline   Reply With Quote
The Following User Says Thank You to 72chevy4x4 For This Useful Post:
Old 02-04-2014, 08:43 PM   #4
ctmcdaniel
Cross Member
ctmcdaniel's Avatar
Yeah, give us some air pressure numbers to work with.
Where exactly do you ride in the back?
How much does the lift equipment weigh? Or what the total amount of weight the van is carrying when it's beating you up?
Can you describe the nature of the roughness? Give some examples?
Tom
2007 Fake Crafter
ctmcdaniel is offline   Reply With Quote
The Following User Says Thank You to ctmcdaniel For This Useful Post:
Old 02-04-2014, 08:46 PM   #5
Mrdi
Mrdi's Avatar
The farther forward you can move the smoother the ride
You could also ADD WEIGHT TO THE BACK TO DAMPEN THE"JUMP".
Mrdi
2008,2500, 144 Hi Cargo
Surf City USA,
Southern California
The Following User Says Thank You to Mrdi For This Useful Post:
SullyVan (02-04-2014)
Old 02-04-2014, 09:23 PM   #6
CJPJ
2008 3500 170"ext. 3.0 V6
CJPJ's Avatar
I can tell you that riding behind the rear axle is always the worst ride, the bumps are amplified back there. Your ride will improve by positioning the chair forward of the rear axle.
Old 02-04-2014, 09:27 PM   #7
Themajickman
My current tires are Michelin LTX M/S 245 x 75 x 16. And they have about 80% tread left
no modifications have been made to the Springs to my knowledge
The Following User Says Thank You to Themajickman For This Useful Post:
Old Crows (02-04-2014)
Old 02-04-2014, 09:30 PM   #8
Themajickman
according to this company I spoke with apparently cargo vans and passenger van do have different springs. And, I do have a set of new Michelin's. Air pressures were said about 65 pounds. I'm thinking of trying to lower the air pressure and see if that will help
Old 02-04-2014, 09:46 PM   #9
Themajickman
as soon as I get back home I can work with some air pressure changes to see if the ride improves without adversely heating up the tires.
I ride a little bit in front of the rear axle offset a little to the left of center line. We leave in the rear set of three seats so I ride in front of them.
Me, my chair and the equipment weigh 750 pounds (approximately).
The roughness is like riding on a solid tire and no suspension.
I really don't have a option as to where I can sit because the tiedowns are fixed in the floor. As it is there is barely room to squeeze between my feet and the front seats so I really can't move much more forward.
Thanks, but I'm riding in front of the rear axle.
I think my best bet is to try different air pressures once I get out of the hospital and see how that works..
Old 02-04-2014, 10:00 PM   #10
Old Crows
Calypso 2014 View Profile
Old Crows's Avatar
FWIW,
Man that just sucks.... We gotta get you a gentler ride.
I'd set the tires to the pressures shown on the driver door placard. No need to go higher... That's the recommended pressure for the rated load.
I'm assuming you are seated either over or behind the rear axle....???? That's not the smoothest ride in any vehicle. Really bad on one with heavy springs and shocks.
Can you move farther forward? Possibly midship between, or nearly so, the two axles. With the Sprinter's flat floor you should be able to get farther forward... Oops! Do you have a second row seat?
That would be my start points.
My RV on a 2500 chassis rode pretty well except for the sofa about 20" from the rear doors. It was kind of bouncy depending on road surfaces. Much smoother between the wheels! Honestly... I don't think changing springs, air bags, shocks will make a whole lot of difference in the ride over or behind the rear axle.
