Old 01-31-2014, 12:11 PM   #1
nctrailseeker
nctrailseeker's Avatar
Default What is the average cost of a head gasket replacement for a 2003 including parts and
What is the average cost of a head gasket replacement for a 2003 including parts and labor?
I'm in North Carolina ...if that matters.
2008 3500 170 Cargo
2003 3500 158 conversion RV
nctrailseeker is offline   Reply With Quote
Old 01-31-2014, 02:49 PM   #2
lindenengineering
Default Re: What is the average cost of a head gasket replacement for a 2003 including parts
Here's a costing overview.
Labor rate is 8 to 12 hours so depending upon shop rates in your area budget around $1000 to $1500.
Parts.
Head set $167.
Misc gaskets incl exhaust manifold & head bolts & thermostat $347.15
Add $140 for glow plugs if necessary.
Add $500 for head overhaul valves and seal extra per requirements.
add $1500 for new injectors should they be elected to install.
add $500 approximately if any injectors have to be eroded out and any studs whiuch cannot be easy outed using an EDM machine.
Add about $125/$150 for new filters and oil using Mobil Delvac 1300 & coolant.
Hope that helps
nctrailseeker (01-31-2014)
Old 01-31-2014, 03:07 PM   #3
rlent Randall gives a nice overview of the process here complete with some tips.
http://sprinter-source.com/forum/sho...523#post201523
Old 01-31-2014, 08:27 PM   #4
mawsea
sprinter guru
mawsea's Avatar
Is this a common failure? A year ago Mercedes told me I needed a new head gasket due to minuscule seepage at the passenger rear of engine. I had a indy mech. do a pressure test and he said it was fine and not to worry. Further research here shows that these head gasket seepage spots are benign. Anyways Mercedes quoted $6000 to pull the engine, fix the black death, replace head gasket, injectors glow plugs and a torque converter that they said was causing the RSN. That was a year ago and since then I only fixed the BLack D for $800 and the tranny fluid ....all seems to be fine.......But head gaskets are at the back of my mind.
Original owner: 2003 2500 144 low cargo 200,000 miles, outfitted for work and play
mawsea is offline   Reply With Quote
Old 01-31-2014, 10:50 PM   #5
lindenengineering
Fine coolant leaks can be stopped with BK Stop Leak.
Being principally constituted from a ground up Brazilian pepper its organic and can be flushed out with plain water. Leak returns!
So good in fact for the potentially expensive leak eradication evenm I use it! And in any case its an official fix for leaking wet liners on LR Flandie V6 engines.
dowdelst (06-21-2018)
Old 02-13-2014, 01:53 PM   #6
MillionMileSprinter
Formerly Type2Teach
MillionMileSprinter's Avatar
Dennis, I just googled "BK Stop Leak" and didn't get any hits. Does it have another name?
Sprinter Mechanic
Joel Sell
For HELP, SERVICE and MORE
The Following User Says Thank You to MillionMileSprinter For This Useful Post:
