Old 01-13-2014, 07:45 PM   #1
kenj356
Default Becker Radio Replacement with Single DIN GPS, CD Player
Has anyone got experience replacing the original radio with a Pyle PLBT72G. This unit has a 7" screen that telescopes out and up from the head unit. It is supposed to fit in a single DIN opening. Does anyone know of any other units available that include GPS, CD, AM/FM, BT and fit in the Sprinter dash opening?
kenj356 is offline   Reply With Quote
Old 01-13-2014, 10:12 PM   #2
pgr
Default Re: Becker Radio Replacement with Single DIN GPS, CD Player
I replaced mine with a similar unit by Jensen a few years back. No GPS but backup camera input for iPhone/iPad for GPS 7" pop out screen. It was cheap, under $300 if I recall) and works great. You just use a VW connector to wire it in. No problems on my T1N.
pgr is offline   Reply With Quote
The Following User Says Thank You to pgr For This Useful Post:
kenj356 (01-14-2014)
Old 01-14-2014, 02:56 AM   #3
kenj356
I'll have to look at Jensen. It's good to know these types of units do fit in a Sprinter. Where did you pick-up the reverse signal for the back-up camera?
Old 01-14-2014, 12:24 PM   #4
pgr
You can just connect a wire on the head unit. The touch screen has several options, CD, Radio, iPad! Camera, etc. You may be able to connect it in to the backup light circuit to actuate it also but I don't use it very much, primarily if I'm towing something, so I never bothered to. If I want it on I just keep it on. The radio/Cd, etc still plays.
If I have time I'll take a photo
Old 01-14-2014, 03:50 PM   #5
kenj356
I was thinking the back-up camera had to be connected so it would switch On when you go in reverse but I see the logic in switching it ON manually when you want it and that probably simplifies the installation a little. Thanks.
Old 01-14-2014, 04:23 PM   #6
pgr
You can do it either (or both probably) way.
Old 01-14-2014, 09:34 PM   #7
pgr
Here's a pic of the screen when it's out
