Old 11-24-2013, 07:45 PM   #1
turnstyler
Default ultra touch denim insulation
Hello,
Has anyone used this stuff?
I'm looking at using this ultra touch denim insulation in addition to my stick on vapor barrier stuff that I put on the metal already.
http://www.homedepot.com/p/UltraTouc...v#.UpJkrGTwI9E
turnstyler is offline   Reply With Quote
The Following User Says Thank You to turnstyler For This Useful Post:
Boz Staggs (11-25-2013)
Old 11-24-2013, 08:37 PM   #2
myhangar
Default Re: ultra touch denim insulation
I'm insulating my sprinter with it now. Easy to work with. No itching. Also using the sound deadening underlay material they sell. Has made a big difference in noise reduction.
myhangar is offline   Reply With Quote
Old 11-24-2013, 08:39 PM   #3
israndy
Custom User Title
israndy's Avatar
I had a bunch left over after installing in a room remodel so I filled the fiberglass overcab area with it to cut down on heat from that severely sun-exposed area of the RV. Problem is it's 4" thick. Few places where you can take advantage of it. I put it behind the Microwave and now I am thinking I might be blocking airflow around it... It's also kind of dust making, the fabric dust is crazy, but only during install. And working with it is SO MUCH nicer than working with fiberglass...
-Randy
T1N 2005 3500 based 2007 Leisure Travel Van's Serenity
Also a 40' Airstream Sky Deck, a 1999 Jeep Grand Cherokee, 2000 Honda Hybrid Insight, new 2013 Volvo C70 hardtop convertible
And all electric: March 2018 Tesla Model Ƹ, 2012 Mitsubishi i-Miev and two 2007 Vectrix VX1 motorcycles
Old 11-24-2013, 08:52 PM   #4
turnstyler
has anyone found a way to buy this other that the "case" quantity offered in the link?
Old 11-25-2013, 02:04 AM   #5
If you look along the right margin of that page, you'll see other put-ups.
One is a 6-pack of 16 inch by 48 inch pieces for $36
http://www.homedepot.com/p/UltraTouc...N#.UpK8_uI0y2A
Given the "case" of the first page, i happened to see the individual 8-packs at Lowe's this afternoon (before seeing this thread). So i'm sure you can get 8 *pieces* of the 24x93 batting (thus 16*8=128 sq ft) as a single purchaseable package.
Likewise, this is a single 48x75 inch piece foil-covered for $28: http://www.homedepot.com/p/UltraTouc...8752/202710039
... it's a water-heater blanket.
Old 11-27-2013, 12:43 AM   #6
rexagon
found a product here in Houston called Bonded Logic which is treated denim also. It works great as sound deadening as well. Used a little spray foam for filling in tight places. Used 1in foam board with foil on one side for roof to get a good radiant barrier. Van is really very comfortable.
rexagon is offline   Reply With Quote
Old 11-27-2013, 02:02 AM   #7
hulagun
Haulin' A** since 1974
hulagun's Avatar
Foil covered sounds like a nice bonus. The water heater blanket is also 2" thick, might that be a better thickness for van use?
2005 T1N 2500 HC OM647 2.7L 5-cyl Turbo Cargo Platinum Silver 118" Wheelbase Moto Hauler
hulagun is offline   Reply With Quote
Old 11-28-2013, 12:20 AM   #8
brokengranite
I used it when insulating my van, awesome stuff to work with. I purchased it at Lowes locally.
brokengranite is offline   Reply With Quote
Old 11-28-2013, 02:33 PM   #9
sunnyside
I grabbed a piece at Lowes and submerged it in water and found it was like a sponge, made me very concerned about condensation issues.
sunnyside is offline   Reply With Quote
The Following 2 Users Say Thank You to sunnyside For This Useful Post:
israndy (11-29-2013), TooMuchHair (11-28-2013)
Old 11-28-2013, 04:07 PM   #10
turnstyler
I thinking that the water heater blankets would be best.
And possibly use foil tape on all exposed edges to seal the denim inside a full vapor barrier.
ckim0321 (12-28-2015)
