Old 09-19-2013, 07:27 PM   #1
siegcw
2011 Mercedes Crew ~10k
Default 2011 Crew Sliding Door and Wall Panel Removal
I'm installing sound dampening/insulation and don't want to mess up the factory sliding door and driver side wall panels. Any tips for removing those panels? Should I use a specific tool or just pull it straight away with my hands? Any input will help. Thanks!
siegcw is offline   Reply With Quote
Old 09-19-2013, 08:34 PM   #2
Evil Patrick
Default Re: 2011 Crew Sliding Door and Wall Panel Removal
AFAIK, not all panels are affixed the same way. Some use the plastic "rivets" and some use sheet metal screws. You certainly do not want to use a "just pull it" technique on either. That probably seems obvious w/ sheet metal screws, so I'll go out on the limb and assume you're asking about removal of the plastic rivets?
2012 NCV3 - 21 mpg (flat, climbing, descending, city, hwy mix...but only if I keep my foot out of it!)
My videos --> http://www.youtube.com/patrel
My music ---> http://www.reverbnation.com/kaleidoscopesundae
Evil Patrick is offline   Reply With Quote
Old 09-19-2013, 08:39 PM   #3
Evil Patrick
Although these are not guaranteed to be replacements, the construction is very similar. Look closely at all the pictures. The center of the rivets should be gently pried out using the recessed "groove" they seat in. Then, the body of the rivet can be pulled out, but some will put up a little fight.
door, panels
