GEARS
2005 140WB standard roof
I few months back I began having trouble with getting out of park and had to start using a pencil to bypass the shifter.
I read some threads and started checking it out.
I checked adjustment of the brake switch, it was fine.
The fuse was fine but I replaced it anyway.
I replaced all the tail light bulbs even though none were burnt out.
I ended up buy a new brake switch even though the original was fine.
I unplugged my trailer brake for giggles.
Nothing changed, still had to use a pencil to get out of park. I wasn't too worried about it as I had brake lights and this is my secondary vehicle.
Fast forward to last week. I started having some odd brakes.
When slowing to a stop the brake pedal sometimes would to drop just a scosh and the brakes would either want to work a little harder then act normal. Only does it every once in a while when the van is just about stopped.
Then I hooked up DAD which said I have these codes:
F1111 an ABS/ASR error
C15FA an ESP error
B1041 some CAN error with the instrument cluster and the traction control unit.
P2203 Y3/6n3 some transmission type error.
P2225 another transmission type error, possibly error 8?
P1630
Any suggestions before I take it to the dealership?
C15FA an ESP error
P1630
