Old 05-04-2013, 06:23 PM   #1
Kenpho10
Default Reverse wire for camera
What wire can I use in the front of the van dash to tap my rear view camera to ( I need the reverse wire). Thanks
Kenpho10 is offline   Reply With Quote
Old 05-04-2013, 11:22 PM   #2
flman
In Transit
flman's Avatar
Default Re: Reverse wire for camera
Either one of the backup lights, the backup system should have a relay, so you will only be supplying the signal.
Even if it's not real, as long as it makes you happy, that is all that matters.
Old 05-04-2013, 11:51 PM   #3
Kenpho10
I use the white wire with thin blue line. That's the wire(+) for the reverse warning module/horn. It is located on the driver side at the pillar or under the dash board. Hopefully that helps.
The Following User Says Thank You to Kenpho10 For This Useful Post:
GSWatson (10-30-2018)
Old 05-05-2013, 03:15 AM   #4
sliver
sliver's Avatar
What model is your van? I wasn't aware there is a reverse warning module/horn. Is that an option, and is that white/blue wire there even if the option is not installed?
sliver is offline   Reply With Quote
Old 05-11-2013, 08:25 AM   #5
Tc3
It's in the drivers side kick panel. White w blue stipe.
Just did mine a couple weeks back.
Tc3 is offline   Reply With Quote
The Following User Says Thank You to Tc3 For This Useful Post:
sliver (05-12-2013)
Old 10-30-2018, 11:00 PM   #6
ltstickers
i can also confirm, as I Just did this to a 2018 Mercades sprinter / 2019 revel
ltstickers is offline   Reply With Quote
Old 10-31-2018, 02:11 AM   #7
F2ca170
My backup warning horn beeper has a feature that it will operate in half volume (loudness) if you put it in reverse twice in short succession. I wonder if the white wire with blue line drops the voltage to make that happen? If it does, then that wire might not always have full voltage on it when using that feature.
I've read where folks use a connection at the gear shifter for a reverse signal.
F2ca170 is offline   Reply With Quote
Old 10-31-2018, 05:11 AM   #8
ptheland
2013 144" low top Passgr
ptheland's Avatar
No, it does not. That is the power to the backup lights.
AFAIK, Sprinters do not have a backup beeper from the factory - at least not in North America. So your backup beeper is probably an aftermarket item. Since it takes two quick shifts into reverse to drop the beeper volume, that is likely a logic circuit inside the aftermarket unit.
--Peter
Old 10-31-2018, 02:43 PM   #9
F2ca170
"No, it does not. That is the power to the backup lights."
Oh, I thought it was determined that the white with blue stripe wire was for the feed to the backup horn/beeper (stated in the third post).
As for the backup horn/beeper being available in NA as an OEM item......
My owners manual tells about the double shift into "R" will drop the volume, and my beeper has OEM wiring. Running the VIN number at the website that shows the build of the van ( https://carinfo.kiev.ua/cars/vin/mercedes/vin_check ) shows "JW0 - BACKUP WARNING SYSTEM" as a factory installed feature on my VIN. So mine seems to be factory OEM. It was a van built for Freightliner for use in North America. This is listed on the build sheet to verify such: ZU8 - USA COUNTRY VERSION and ZX9 - FREIGHTLINER EXECUTION.
Someone else asked a while back why I had white steel wheels, that those were only on Fedex vans in North America. Yet my build sheet shows RM2 - STEEL WHEELS ARCTIC WHITE as the factory installed wheels.
So it really boils down too.... if you get a van that was built for a particular customer in NA, you might have stuff that doesn't come standard (or isn't even available) when an individual person is buying just one of them. Difference in regular Sales and Fleet Sales
Old 10-31-2018, 11:01 PM   #10
ptheland
ptheland's Avatar
Looks like I'm learning something the hard way again. Sorry about the mistake.
I'm pretty sure I've heard others mention the white/blue wire as the power to the white backup lights. But I suppose I could be mis-remembering that, too.
However, for purposes of attaching a trigger for a backup camera, I doubt that the exact voltage on the signal line is all that important. As long as its significantly different from ground, I suspect any voltage is fine.
--Peter
